Solaris Common Desktop Environment: User's Guide
Performing Window List Tasks From the Window Menu
There are a number of tasks that you can perform using the Window List. They are:
Figure 7–6 Window List Window Menu
Graphic
To Go To a Window
  1. Select a window from the Window List.
  2. Choose Go To Window from the Window menu.
Note –
Depending on the setting of the Window List Options, you may be able to double-click on the Window List entry and move to the workspace that contains the selected window or have the window move to the current workspace. Refer to To Set the Action of a Double-click on a Window Entry.
To Get a Window
  2. Choose Get Window from the Window menu.
    Window appears in the current workspace.
To Lower a Window in the Stack
  2. Choose Lower from the Window menu.
To Minimize the Selected Window(s)
  1. Select a window(s) from the Window list.
  2. Choose Minimize from the Window menu.
To Close a Window
  1. Select a window(s) from the Window List.
  2. Choose Close Window from the Window menu.
  3. (Optional) If the window being closed is the only window that contains a given application, a confirmation dialog box will appear. Click OK, if you want to close the window and terminate the application.
To Terminate an Application
  2. Choose Terminate Application from the Window menu.
To Move the Selected Window(s) Into Another Workspace
  2. Choose Move to Workspace from the Window menu.
  3. Choose a workspace or All Workspaces.
To Occupy the Selected Workspace
  2. Choose Occupy a Workspace from the Window menu.
  3. Choose the workspace you want the window to occupy from the Occupy Workspace dialog box.
To Unoccupy the Selected Workspace
  2. Choose Unoccupy a Workspace from the Window menu.
To Cascade all Non-minimized Windows in a Workspace
This occurs only in the current workspace.
    Choose Cascade All in Workspace from the Window menu.
To Tile all Non-minimized Windows in a Workspace
  1. Choose Tile All in Workspace from the Window menu.
  2. Click Horizontal or Vertical from the submenu.
