Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Key Configuration Files
Most customization of your desktop environment can involve many files. The following files are two examples:
Xconfig
Xconfig is the master configuration file used by dtlogin. It sets login resources and specifies locations of additional files required by dtlogin. The following example shows a few of the lines found in the default Xconfig file:
	Dtlogin.errorLogFile:       /var/dt/Xerrors
	Dtlogin.servers:            /usr/dt/config/Xservers
	Dtlogin*session:            /usr/dt/bin/Xsession
For more information about this file, refer to Appendix A, dtconfig(1) Man Page. You can also review the explanatory comments in the file itself.
Xservers
dtlogin, like XDM (X Display Manager) on which it is based, uses the Xservers file to specify how the local Xserver is started. By default, the last line in this file is:
:0 Local local@console /usr/openwin/bin/Xsun :0
Note –
Replace local with foreign if you want to attach to a running X11 server.
Note –
The Solaris CDE and OpenWindowsTM environments run the same X11 server.
Refer to the dtlogin(1) man page for more information about this file. You can also review the explanatory comments in the file itself.
