SPARC Assembly Language Reference Manual
5.4 Coprocessor Instructions
All coprocessor-operate (cpopn) instructions take all operands from and return all results to coprocessor registers. The data types supported by the coprocessor are coprocessor-dependent. Operand alignment is also coprocessor-dependent. Coprocessor-operate instructions are described in Table 5–5.
If the EC (PSR_enable_coprocessor) field of the processor state register (PSR) is 0, or if a coprocessor is not present, a cpopn instruction causes a cp_disabled trap.
The conditions that cause a cp_exception trap are coprocessor-dependent.
Table 5–5
SPARC
Mnemonic
Argument List
Name
Comments
CPop1
cpop1
opc, regrs1, regrs2, regrd
Coprocessor operation
CPop2
cpop2
May modify ccc
