Table 5–6 describes the mapping of synthetic instructions to hardware instructions.
Table 5–6
Synthetic Instruction |
Hardware Equivalent(s) |
Comment |
btst |
reg_or_imm, regrs1 |
andcc |
regrs1, reg_or_imm, %g0 |
Bit test |
bset |
reg_or_imm, regrd |
or |
regrd, reg_or_imm, regrd |
Bit set |
bclr |
reg_or_imm, regrd |
andn |
Bit clear |
btog |
reg_or_imm, regrd |
xor |
Bit toggle |
call |
reg_or_imm |
jmpl |
reg_or_imm, %o7 |
clr |
regrd |
or |
%g0, %g0, regrd |
Clear (zero) register |
clrb |
[address] |
stb |
%g0, [address] |
Clear byte |
clrh |
[address] |
st |
%g0, [address] |
Clear halfword |
clr |
[address] |
st |
%g0, [address] |
Clear word |
cmp |
reg, reg_or_imm |
subcc |
Compare |
dec |
regrd |
sub |
regrd, 1, regrd |
Decrement by 1 |
dec |
const13, regrd |
sub |
regrd, const13, regrd |
Decrement by const13 |
deccc |
regrd |
subcc |
regrd, 1, regrd |
Decrement by 1 and set icc |
deccc |
const13, regrd |
subcc |
Decrement by const13 and set icc |
inc |
regrd |
add |
regrd, 1, regrd |
Increment by 1 |
inc |
const13, regrd |
add |
Increment by const13 |
inccc |
regrd |
addcc |
regrd, 1, regrd |
Increment by 1 and set icc |
inccc |
const13, regrd |
addcc |
Increment by const13 and set icc |
jmp |
address |
jmpl |
address, %g0 |
mov mov mov mov mov mov mov mov mov |
reg_or_imm,regrd %y, regrs1 %psr, regrs1 %wim, regrs1 %tbr, regrs1 reg_or_imm, %y reg_or_imm, %psr reg_or_imm, %wim reg_or_imm, %tbr |
or rd rd rd rd wr wr wr wr |
%g0, reg_or_imm, regrd %y, regrs1 %psr, regrs1 %wim, regrs1 %tbr, regrs1 %g0,reg_or_imm,%y %g0,reg_or_imm,%psr %g0,reg_or_imm,%wim %g0,reg_or_imm,%tbr |
not |
regrs1, regrd |
xnor |
regrs1, %g0, regrd |
One's complement |
not |
regrd |
xnor |
regrd, %g0, regrd |
One's complement |
neg |
regrs1, regrd |
sub |
%g0, regrs2, regrd |
Two's complement |
neg |
regrd |
sub |
%g0, regrd, regrd |
Two's complement |
restore |
restore |
%g0, %g0, %g0 |
Trivial restore |
save |
save |
%g0, %g0, %g0 |
Trivial save trivial save should only be used in supervisor code! |
set |
value,regrd |
or |
%g0, value, regrd |
if -4096 ≤value ≤ 4095 Do not use the set synthetic instruction in an instruction delay slot. |
set |
value,regrd |
sethi |
%hi(value), regrd |
if ((value & 0x3ff) == 0) |
set |
value, regrd |
sethi or |
%hi(value), regrd; regrd, %lo(value), regrd |
otherwise Do not use the set synthetic instruction in an instruction delay slot. |
skipz |
bnz,a .+8 |
if z is set, ignores next instruction |
skipnz |
bz,a .+8 |
if z is not set, ignores next instruction |
tst |
reg |
orcc |
regrs1, %g0, %g0 |
test |
