このテンプレートでは、dhcptab コンテナとともに使用される関数が例示されています。
/* * Copyright (c) 1998-2000 by Sun Microsystems, Inc. * All rights reserved. */ #pragma ident "@(#)dhcptab.c 1.12 00/08/16 SMI" /* * This module contains the public API functions for managing the dhcptab * container. */ #include <unistd.h> #include <sys/types.h> #include <sys/socket.h> #include <netinet/in.h> #include <dhcp_svc_public.h> /* * List the current number of dhcptab container objects located at * "location" in "listppp". Return number of list elements in "count". * If no objects exist, then "count" is set to 0 and DSVC_SUCCESS is * returned. * * This function will block waiting for a result, if the underlying * data store is busy. */ int list_dt(const char *location, char ***listppp, uint32_t *count) { return (DSVC_UNSUPPORTED); } /* * Creates or opens the dhcptab container in "location" and initializes * "handlep" to point to the instance handle. When creating a new dhcptab, * the caller's identity is used for owner/permissions. Performs any * initialization needed by data store. */ int open_dt(void **handlep, const char *location, uint32_t flags) { return (DSVC_UNSUPPORTED); } /* * Frees instance handle, cleans up per instance state. */ int close_dt(void **handlep) { return (DSVC_UNSUPPORTED); } /* * Remove dhcptab container in "location" from data store. If the underlying * data store is busy, this function will block. */ int remove_dt(const char *location) { return (DSVC_UNSUPPORTED); } /* * Searches the dhcptab container for instances that match the query * described by the combination of query and targetp. If the partial * argument is true, then lookup operations that are unable to * complete entirely are allowed (and considered successful). The * query argument consists of 2 fields, each 16 bits long. The lower * 16 bits selects which fields {key, flags} of targetp are to be * considered in the query. The upper 16 bits identifies whether a * particular field value must match (bit set) or not match (bit * clear). Bits 2-15 in both 16 bit fields are currently unused, and * must be set to 0. The count field specifies the maximum number of * matching records to return, or -1 if any number of records may be * returned. The recordsp argument is set to point to the resulting * list of records; if recordsp is passed in as NULL then no records * are actually returned. Note that these records are dynamically * allocated, thus the caller is responsible for freeing them. The * number of records found is returned in nrecordsp; a value of 0 * means that no records matched the query. */ int lookup_dt(void *handle, boolean_t partial, uint32_t query, int32_t count, const dt_rec_t *targetp, dt_rec_list_t **recordsp, uint32_t *nrecordsp) { return (DSVC_UNSUPPORTED); } /* * Add the record pointed to by "addp" to from the dhcptab container * referred to by the handle. The underlying public module will set * "addp's" signature as part of the data store operation. */ int add_dt(void *handle, dt_rec_t *addp) { return (DSVC_UNSUPPORTED); } /* * Atomically modify the record "origp" with the record "newp" in the * dhcptab container referred to by the handle. "newp's" signature will * be set by the underlying public module. If an update collision * occurs, either because "origp's" signature in the data store has changed * or "newp" would overwrite an existing record, DSVC_COLLISION is * returned and no update of the data store occurs. */ int modify_dt(void *handle, const dt_rec_t *origp, dt_rec_t *newp) { return (DSVC_UNSUPPORTED); } /* * Delete the record referred to by dtp from the dhcptab container * referred to by the handle. If "dtp's" signature is zero, the * caller is not interested in checking for collisions, and the record * should simply be deleted if it exists. If the signature is non-zero, * and the signature of the data store version of this record do not match, * an update collision occurs, no deletion of matching record in data store * is done, and DSVC_COLLISION is returned. */ int delete_dt(void *handle, const dt_rec_t *dtp) { return (DSVC_UNSUPPORTED); }
