Solaris DHCP サービス開発ガイド
DHCP ネットワークコンテナの API 関数
このテンプレートでは、DHCP ネットワークコンテナとともに使用される関数が例示されています。
例 4–3 dhcp_network.c
 * Copyright (c) 1998-2000 by Sun Microsystems, Inc.
 * All rights reserved.
#pragma	ident	"@(#)dhcp_network.c	1.12	00/08/16 SMI"
 * This module contains public API functions for managing dhcp network
 * containers.
#include <unistd.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <dhcp_svc_public.h>
 * List the current number of dhcp network container objects located at
 * "location" in "listppp". Return number of list elements in "count".
 * If no objects exist, then "count" is set to 0 and DSVC_SUCCESS is
 * returned.
 * This function will block if the underlying data service is busy or is
 * otherwise unvailable.
int
list_dn(const char *location, char ***listppp, uint32_t *count)
	return (DSVC_UNSUPPORTED);
 * Creates or opens the dhcp network container "netp" (host order) in
 * "location" and initializes "handlep" to point to the instance handle.
 * Performs any initialization needed by data store. New containers are
 * created with the identity of the caller.
int
open_dn(void **handlep, const char *location, uint32_t flags,
    const struct in_addr *netp)
 * Frees instance handle, cleans up per instance state.
int
close_dn(void **handlep)
 * Remove DHCP network container "netp" (host order) in location.
 * otherwise unavailable.
int
remove_dn(const char *location, const struct in_addr *netp)
 * Searches DHCP network container for instances that match the query
 * described by the combination of query and targetp.  If the partial
 * argument is true, then lookup operations that are unable to
 * complete entirely are allowed (and considered successful).  The
 * query argument consists of 2 fields, each 16 bits long.  The lower
 * 16 bits selects which fields {client_id, flags, client_ip,
 * server_ip, expiration, macro, or comment} of targetp are to be
 * considered in the query.  The upper 16 bits identifies whether a
 * particular field value must match (bit set) or not match (bit
 * clear).  Bits 7-15 in both 16 bit fields are currently unused, and
 * must be set to 0.  The count field specifies the maximum number of
 * matching records to return, or -1 if any number of records may be
 * returned.  The recordsp argument is set to point to the resulting
 * list of records; if recordsp is passed in as NULL then no records
 * are actually returned. Note that these records are dynamically
 * allocated, thus the caller is responsible for freeing them.  The
 * number of records found is returned in nrecordsp; a value of 0 means
 * that no records matched the query.
int
lookup_dn(void *handle, boolean_t partial, uint32_t query, int32_t count,
    const dn_rec_t *targetp, dn_rec_list_t **recordsp, uint32_t *nrecordsp)
 * Add the record pointed to by "addp" to from the dhcp network container
 * referred to by the handle.  The underlying public module will set
 * "addp's" signature as part of the data store operation.
int
add_dn(void *handle, dn_rec_t *addp)
 * Atomically modify the record "origp" with the record "newp" in the dhcp
 * network container referred to by the handle.  "newp's" signature will
 * be set by the underlying public module.  If an update collision
 * occurs, either because "origp's" signature in the data store has changed
 * or "newp" would overwrite an preexisting record, DSVC_COLLISION is
 * returned and no update of the data store occurs.
int
modify_dn(void *handle, const dn_rec_t *origp, dn_rec_t *newp)
 * Delete the record pointed to by "pnp" from the dhcp network container
 * referred to by the handle. If "pnp's" signature is zero, the caller
 * is not interested in checking for collisions, and the record should
 * simply be deleted if it exists. If the signature is non-zero, and the
 * signature of the data store version of this record do not match, an
 * update collision occurs, no deletion of any record is done, and
 * DSVC_COLLISION is returned.
int
delete_dn(void *handle, const dn_rec_t *pnp)
