At the beginning of each soft partition extent, a sector is used to mark the beginning of the soft partition extent. These hidden sectors are called extent headers. These headers do not appear to the user of the soft partition. If all Solaris Volume Manager configuration data is lost, the disk can be scanned in an attempt to generate the configuration data.
This procedure is a last option to recover lost soft partition configuration information. The metarecover command should only be used when you have lost both your metadb and md.cf files, and your md.tab file is lost or out of date.
This procedure only works to recover soft partition information. This procedure does not assist in recovering from other lost configurations or for recovering configuration information for other Solaris Volume Manager volumes.
If your configuration included other Solaris Volume Manager volumes that were built on top of soft partitions, you should recover the soft partitions before attempting to recover the other volumes.
Configuration information about your soft partitions is stored on your devices and in your state database. Since either source could be corrupt, you must indicate to the metarecover command which source is reliable.
First, use the metarecover command to determine whether the two sources agree. If they do agree, the metarecover command cannot be used to make any changes. However, if the metarecover command reports an inconsistency, you must examine its output carefully to determine whether the disk or the state database is corrupt. Then, you should use the metarecover command to rebuild the configuration based on the appropriate source.
Review the soft partition recovery information by using the metarecover command.
# metarecover component-p -d |
Specifies the cntndnsnname of the raw component
Specifies to regenerate soft partitions
Specifies to scan the physical slice for extent headers of soft partitions
# metarecover c1t1d0s1 -p -d
The following soft partitions were found and will be added to
your metadevice configuration.
Name Size No. of Extents
d10 10240 1
d11 10240 1
d12 10240 1
d10 10240 1
d11 10240 1
d12 10240 1
WARNING: You are about to add one or more soft partition
metadevices to your metadevice configuration. If there
appears to be an error in the soft partition(s) displayed
above, do NOT proceed with this recovery operation.
Are you sure you want to do this (yes/no)?yes
c1t1d0s1: Soft Partitions recovered from device.
bash-2.05# metastat
d10: Soft Partition
Device: c1t1d0s1
State: Okay
Device Start Block Dbase Reloc
c1t1d0s1 0 No Yes
Extent Start Block Block count
0 1 10240
d11: Soft Partition
Device: c1t1d0s1
State: Okay
c1t1d0s1 0 No Yes
0 10242 10240
d12: Soft Partition
Device: c1t1d0s1
State: Okay
c1t1d0s1 0 No Yes
0 20483 10240
In this example, three soft partitions are recovered from disk, after the state database replicas were accidentally deleted.
