If you use NIS+ as the DHCP data store, problems that you might encounter can be categorized as follows:
If you try to use NIS+ as your data store, DHCP Manager might not offer NIS+ as a choice for the data store. If you use the dhcpconfig command, you might see a message stating that NIS+ does not appear to be installed and running. Both these symptoms mean that NIS+ has not been configured for this server, although NIS+ might be in use on the network. Before you can select NIS+ as a data store, the server system must be configured as an NIS+ client.
Before you set up the DHCP server system as an NIS+ client, the following statements must be true:
The domain must have already been configured.
The NIS+ domain's master server must be running.
The master server's tables must be populated.
The hosts table must have an entry for the new client system, the DHCP server system.
Setting Up NIS+ Client Machines in System Administration Guide: Naming and Directory Services (NIS+) provides detailed information about configuring an NIS+ client.
After you successfully use NIS+ with DHCP, you might encounter errors if changes are made to NIS+. The changes could introduce configuration problems. Use the following explanations of problems and solutions to help you determine the cause of configuration problems.
Problem:Root object does not exist in the NIS+ domain.
Solution:Type the following command:
/usr/lib/nis/nisstat
This command displays statistics for the domain. If the root object does not exist, no statistics are returned.
Set up the NIS+ domain using the System Administration Guide: Naming and Directory Services (NIS+).
Problem:NIS+ is not used for passwd and publickey information.
Solution:Type the following command to view the configuration file for the name service switch:
cat /etc/nsswitch.conf
Check the passwd and publickey entries for the “nisplus” keyword. Refer to the System Administration Guide: Naming and Directory Services (NIS+) for information about configuring the name service switch.
Problem:The domain name is empty.
domainname
If the command lists an empty string, no domain name has been set for the domain. Use local files for your data store, or set up an NIS+ domain for your network. Refer to the System Administration Guide: Naming and Directory Services (NIS+).
Problem:The NIS_COLD_START file does not exist.
Solution:Type the following command on the server system to determine if the file exists:
cat /var/nis/NIS_COLD_START
Use local files for your data store, or create an NIS+ client. Refer to the System Administration Guide: Naming and Directory Services (NIS+).
NIS+ access problems might cause error messages about incorrect DES credentials, or inadequate permissions to update NIS+ objects or tables. Use the following explanations of problems and solutions to determine the cause of NIS+ access errors you receive.
Problem:The DHCP server system does not have create access to the org_dir object in the NIS+ domain.
nisls -ld org_dir |
The access rights are listed in the form r---rmcdrmcdr---, where the permissions apply respectively to nobody, owner, group, and world. The owner of the object is listed next.
Normally, the org_dir directory object provides full rights to both the owner and the group. Full rights consist of read, modify, create, and destroy. The org_dir directory object provides only read access to the world and nobody classes.
The DHCP server name must either be listed as the owner of the org_dir object, or be listed as a principal in the group. The group must have create access. List the group with the command:
nisls -ldg org_dir |
Use the nischmod command to change the permissions for org_dir if necessary. For example, to add create access to the group, you would type the following command:
nischmod g+c org_dir |
See the nischmod(1) man page for more information.
Problem:The DHCP server does not have access rights to create a table under the org_dir object.
Usually, this problem means the server system's principal name is not a member of the owning group for the org_dir object, or no owning group exists.
Solution:Type this command to find the owning group name:
niscat -o org_dir |
Look for a line that is similar to:
Group : "admin.example.com."
List the principal names in the group using the command:
nisgrpadm -l groupname |
For example, this command lists the principal names of the group admin.example.com:
nisgrpadm -l admin.example.com
The server system's name should be listed as an explicit member of the group or included as an implicit member of the group. If necessary, add the server system's name to the group using the nisgrpadm command.
For example, to add the server name pacific to the group admin.example.com, you would type the following command:
nisgrpadm -a admin.example.com pacific.example.com |
See the nisgrpadm(1) man page for more information.
Problem:The DHCP server does not have valid Data Encryption Standard (DES) credentials in the NIS+ cred table.
Solution:If there is a credential problem, an error message states that the user does not have DES credentials in the NIS+ name service.
Use the nisaddcred command to add security credentials for the DHCP server system.
The following example shows how to add DES credentials for the system mercury in the domain example.com:
nisaddcred -p unix.mercury@example.com \ -P mercury.example.com. DES example.com. |
The command prompts for the root password, which is required to generate an encrypted secret key.
See the nisaddcred(1M) man page for more information.
