Assume the Primary Administrator role, or become superuser, on the system where you want to enable Mobile IP.
The Primary Administrator role includes the Primary Administrator profile. To create the role and assign the role to a user, see Chapter 2, Working With the Solaris Management Console (Tasks), in System Administration Guide: Basic Administration.
Type the following command for each label that you want to modify in the Address section:
# mipagentconfig change addr [NAI | IPaddr | node-default] <label> <value> |
See Address Section for a description of the three configuration methods (NAI, IP address, and node-default).
For example, if you are changing the SPI of IP address 10.1.1.1 to 258, use the following command:
# mipagentconfig change addr 10.1.1.1 SPI 258 |
The following example shows how you can change other parameters that are provided in the sample configuration file's Address section.
# mipagentconfig change addr 10.1.1.1 Type agent # mipagentconfig change addr 10.1.1.1 SPI 259 # mipagentconfig change addr mobilenode@abc.com Type node # mipagentconfig change addr mobilenode@abc.com SPI 258 # mipagentconfig change addr mobilenode@abc.com Pool 2 # mipagentconfig change addr node-default SPI 259 # mipagentconfig change addr node-default Pool 3 # mipagentconfig change addr 10.68.30.36 Type agent # mipagentconfig change addr 10.68.30.36 SPI 260 |
