Advertisements Section
The Advertisements section contains the HomeAgent and ForeignAgent labels, as well as other labels.
You must include a different Advertisements section for
each interface on the local host that provides Mobile IP services. The Advertisements section has the following syntax:
[Advertisements interface]
HomeAgent = <yes/no>
ForeignAgent = <yes/no>
Typically, your
system has a single interface, such as eri0 or hme0,
and supports both home agent and foreign agent operations. If this situation
exists for the example hme0, then the yes value
is assigned to both the HomeAgent and ForeignAgent labels
as follows:
[Advertisements hme0]
HomeAgent = yes
ForeignAgent = yes
For advertisement over dynamic interfaces, use '*' for the device ID
part. For example, Interface-name ppp* actually
implies all PPP interfaces that are configured after the mipagent daemon
has been started. All the attributes in the advertisement section of a dynamic
interface type remain the same.
The following table describes
the labels and values that you can use in the Advertisements section.
Table 29–1
Advertisements Section Labels and Values
Label
Value
Description
HomeAgent
yes or no
Determines if the mipagent daemon provides
home agent functionality.
ForeignAgent
yes or no
Determines if mipagent provides foreign agent
functionality.
PrefixFlags
yes or no
Specifies if advertisements include the optional prefix-length
extension.
AdvertiseOnBcast
yes or no
If yes, advertisements are sent on 255.255.255.255, rather than 224.0.0.1.
RegLifetime
n
The maximum lifetime value that is accepted in registration requests,
in seconds.
AdvLifetime
n
The maximum length of time that the advertisement is considered
valid in the absence of further advertisements, in seconds.
AdvFrequency
n
Time between two consecutive advertisements, in seconds.
ReverseTunnel
yes or noFA or HA or both
Determines if mipagent provides reverse-tunnel functionality.
The value yes means that both the foreign agent and
home agent support reverse tunneling. The value no means
that the interface does not support reverse tunneling.
The value FA means that the foreign agent supports
reverse tunneling. The value HA means that the home agent
supports reverse tunneling. The value both means that both
the foreign agent and home agent support reverse tunneling.
ReverseTunnelRequired
yes or no
Determines if mipagent requires reverse tunnel functionality.
Consequently, determines if a mobile node must request a reverse tunnel during
registration.
home agent require a reverse tunnel. The value no means
that the interface does not require a reverse tunnel.
The value FA means that the foreign agent requires
a reverse tunnel. The value HA means that the home agent
requires a reverse tunnel.
AdvInitCount
n
Determines the initial number of unsolicited advertisements. The
default value is 1. This value is meaningful only if AdvLimitUnsolicited is yes.
AdvLimitUnsolicited
yes or no
Enables or disables a limited number of unsolicited advertisements
over the mobility interface.
