The following listing shows the sections, labels, and values that are contained in the mipagent.conf.ha-sample file. Configuration File Sections and Labels describes the syntax, sections, labels, and values.
The mipagent.conf.ha-sample file shows a configuration that provides only home agent functionality. Otherwise, this file is the same as the mipagent.conf-sample file.
[General] Version = 1.0 # version number for the configuration file. (required) [Advertisements hme0] HomeAgent = yes ForeignAgent = no PrefixFlags = yes AdvertiseOnBcast = yes RegLifetime = 200 AdvLifetime = 200 AdvFrequency = 5 ReverseTunnel = yes ReverseTunnelRequired = no [GlobalSecurityParameters] MaxClockSkew = 300 HA-FAauth = yes MN-FAauth = yes Challenge = no KeyDistribution = files [Pool 1] BaseAddress = 10.68.30.7 Size = 4 [SPI 257] ReplayMethod = none Key = 11111111111111111111111111111111 [SPI 258] ReplayMethod = none Key = 15111111111111111111111111111111 [Address 10.1.1.1] Type = node SPI = 258 [Address mobilenode@sun.com] Type = node SPI = 257 Pool = 1 [Address Node-Default] Type = node SPI = 258 Pool = 1 |
