You can readily set up a mail service if your site does not provide connections to email services outside your company or if your company is in a single domain.
Mail requires two types of configurations for local mail. Refer to Figure 13–1 in Local Mail Only for a representation of these configurations. Mail requires two more configurations for communication with networks outside your domain. Refer to Figure 12–1 in Overview of the Hardware Components or Figure 13–2 in Local Mail and a Remote Connection for a representation of these configurations. You can combine these configurations on the same system or provide these configurations on separate systems. For example, if your mail host and mail server functions are on the same system, follow the directions in this section for setting up that system as a mail host. Then, follow the directions in this section for setting up the same system as a mail server.
The following procedures for setting up a mail server and mail client apply when mailboxes are NFS mounted. However, mailboxes typically are maintained in locally mounted /var/mail directories, which eliminates the need for the following procedures.
No special steps are required to set up a mail server that is only serving mail for local users. The user must have an entry in the password file or in the namespace. Also, for mail to be delivered, the user should have a local home directory for checking the ~/.forward file. For this reason, home directory servers are often set up as the mail server. Hardware Components in Chapter 14, Mail Services (Reference) provides more information about the mail server.
The mail server can route mail for many mail clients. This type of mail server must have adequate spooling space for client mailboxes.
The mail.local program automatically creates mailboxes in the /var/mail directory the first time a message is delivered. You do not need to create individual mailboxes for your mail clients.
For clients to access their mailboxes, the /var/mail directory should be available for remote mounting. Alternately, a service such as Post Office Protocol (POP) or Internet Message Access Protocol (IMAP) should be available from the server. The following task shows you how to set up a mail server by using the /var/mail directory. To provide configuration guidelines for POP or IMAP is beyond the scope of this document.
For the following task, ensure that the /etc/dfs/dfstab file shows that the /var/mail directory is exported.
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Stop sendmail.
# svcadm disable -t network/smtp:sendmail |
Check if the /var/mail directory is available for remote access.
# share |
If the /var/mail directory is listed, proceed to step 5.
If the /var/mail directory is not listed or if no list appears, continue with the appropriate substep.
(Optional) If no list appears, start NFS services.
Follow the procedure, How to Set Up Automatic File-System Sharing, to use the /var/mail directory to start NFS services.
(Optional) If the /var/mail directory is not included in the list, add the directory to /etc/dfs/dfstab.
Add the following command line to the /etc/dfs/dfstab file.
share -F nfs -o rw /var/mail |
Make the file system available for mounting.
# shareall |
Ensure that your name service has been started.
(Optional) If you are running NIS, use this command.
# ypwhich |
For more information, refer to the ypwhich(1) man page.
(Optional) If you are running NIS+, use this command.
# nisls |
For more information, refer to the nisls(1) man page.
(Optional) If you are running DNS, use this command.
# nslookup hostname |
Use your host name.
For more information, refer to the nslookup(1M) man page.
(Optional) If you are running LDAP, use this command.
# ldaplist |
For more information, refer to the ldaplist(1) man page.
Restart sendmail.
# svcadm enable network/smtp:sendmail |
A mail client is a user of mail services with a mailbox on a mail server. Additionally, the mail client has a mail alias in the /etc/mail/aliases file that points to the location of the mailbox.
You can also perform the task of setting up a mail client by using a service such as Post Office Protocol (POP) or Internet Message Access Protocol (IMAP). However, to provide configuration guidelines for POP or IMAP is beyond the scope of this document.
Become superuser on the mail client's system or assume an equivalent role.
Stop sendmail.
Ensure that a /var/mail mount point exists on the mail client's system.
The mount point should have been created during the installation process. You can use ls to ensure that the file system exists. The following example shows the response that you receive if the file system has not been created.
# ls -l /var/mail /var/mail not found |
Ensure that no files are in the /var/mail directory.
If mail files do exist in this directory, you should move them so that they are not covered when the /var/mail directory is mounted from the server.
Mount the /var/mail directory from the mail server.
You can mount the mail directory automatically or at boot time.
(Optional) Mount /var/mail automatically.
Add an entry such as the following to the /etc/auto_direct file.
/var/mail -rw,hard,actimeo=0 server:/var/mail |
Use the assigned server name.
(Optional) Mount /var/mail at boot time.
Add the following entry to the /etc/vfstab file. This entry permits the /var/mail directory on the mail server that is specified to mount the local /var/mail directory.
server:/var/mail - /var/mail nfs - no rw,hard,actimeo=0 |
The client's mailbox is automatically mounted whenever the system is rebooted. If you are not rebooting the system, type the following command to mount the client mailbox.
# mountall |
For mailbox locking and mailbox access to work properly, you must include the actimeo=0 option when mounting mail from an NFS server.
Update /etc/hosts.
Edit the /etc/hosts file and add an entry for the mail server. This step is not required if you are using a name service.
# cat /etc/hosts # # Internet host table # .. IP-address mailhost mailhost mailhost.example.com |
Use the assigned IP addresses.
Use the assigned domain.
Use the assigned mailhost.
For more information, refer to the hosts(4) man page.
Add an entry for the client to one of the alias files.
Refer to Administering Mail Alias Files (Task Map) for a task map about administering mail alias files. Note that the mail.local program automatically creates mailboxes in the /var/mail directory the first time a message is delivered. You do not need to create individual mailboxes for your mail clients.
Restart sendmail.
A mail host resolves email addresses and reroutes mail within your domain. A good candidate for a mail host is a system that provides your network with a remote connection or connects your network to a parent domain. The following procedure shows you how to set up a mail host.
Become superuser on the mail host system or assume an equivalent role.
Stop sendmail.
Verify the host-name configuration.
Run the check-hostname script to verify that sendmail can identify the fully qualified host name for this server.
% /usr/sbin/check-hostname hostname phoenix OK: fully qualified as phoenix.example.com |
If this script is not successful in identifying the fully qualified host name, you need to add the fully qualified host name as the first alias for the host in /etc/hosts.
Update the /etc/hosts file.
Choose the step that is appropriate for you.
(Optional) If you are using NIS or NIS+, edit the /etc/hosts file on the system that is to be the new mail host.
Add the word mailhost and mailhost.domain after the IP address and system name of the mail host system.
IP-address mailhost mailhost mailhost.domain loghost |
Use the assigned IP address.
Use the system name of the mail host system.
Use the expanded domain name.
The system is now designated as a mail host. The domain should be identical to the string that is given as the subdomain name in the output of the following command.
% /usr/lib/sendmail -bt -d0 </dev/null
Version 8.13.1+Sun
Compiled with: LDAPMAP MAP_REGEX LOG MATCHGECOS MIME7TO8 MIME8TO7
NAMED_BIND NDBM NETINET NETINET6 NETUNIX NEWDB NIS
NISPLUS QUEUE SCANF SMTP USERDB XDEBUG
============ SYSTEM IDENTITY (after readcf) ============
(short domain name) $w = phoenix
(canonical domain name) $j = phoenix.example.com
(subdomain name) $m = example.com
(node name) $k = phoenix
See the following example of how the hosts file should look after these changes.
# cat /etc/hosts # # Internet host table # 172.31.255.255 localhost 192.168.255.255 phoenix mailhost mailhost.example.com loghost |
(Optional) If you are not using NIS or NIS+, edit the /etc/hosts file on each system in the network.
Create the following entry.
Restart sendmail.
Test your mail configuration.
See How to Test the Mail Configuration for instructions.
For further information about mail hosts, refer to Hardware Components in Chapter 14, Mail Services (Reference).
A mail gateway manages communication with networks outside your domain. The mailer on the sending mail gateway can match the mailer on the receiving system.
A good candidate for a mail gateway is a system that is attached to Ethernet and phone lines. Another good candidate is a system that is configured as a router to the Internet. You can configure the mail host or another system as the mail gateway. You might choose to configure more than one mail gateway for your domain. If you have UNIX-to-UNIX Copy Program (UUCP) connections, you should configure the system (or systems) with UUCP connections as the mail gateway.
Become superuser on the mail gateway or assume an equivalent role.
Stop sendmail.
# /usr/sbin/check-hostname hostname phoenix OK: fully qualified as phoenix.example.com |
If this script is not successful in identifying the fully qualified host name, you need to add the fully qualified host name as the first alias for the host in /etc/hosts. If you need help with this step, refer to Step 4 of How to Set Up a Mail Host.
# ypwhich |
# nisls |
Use your host name.
# ldaplist |
Restart sendmail.
For more information about the mail gateway, refer to Hardware Components in Chapter 14, Mail Services (Reference).
The DNS name service does not support aliases for individuals. This name service does support aliases for hosts or domains that use Mail Exchanger (MX) records and CNAME records. You can specify host names, domain names, or both names in the DNS database. For more information about sendmail and DNS, see Interactions of sendmail With Name Services in Chapter 14, Mail Services (Reference), or see the System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP).
Enable DNS host lookups (NIS+ only).
Edit the /etc/nsswitch.conf file and remove the # from the hosts definition that includes the dns flag. The host entry must include the dns flag, as the following example shows, in order for the DNS host aliases to be used.
# grep hosts /etc/nsswitch.conf #hosts: nisplus [NOTFOUND=return] files hosts: dns nisplus [NOTFOUND=return] files |
Check for a mailhost and mailhost.domain entry.
Use nslookup to ensure that an entry exists for mailhost and mailhost.domain in the DNS database. For more information, refer to the nslookup(1M) man page.
