The ftp command opens the user interface to the Internet's File Transfer Protocol. This user interface, called the command interpreter, enables you to log in to a remote system and perform a variety of operations with its file system. The principal operations are summarized in the following table.
The main benefit of ftp over rlogin and rcp is that ftp does not require the remote system to be running UNIX. The remote system does, however, need to be configured for TCP/IP communications. However, rlogin provides access to a richer set of file manipulation commands than ftp provides.
Authentication for ftp remote login operations can be established by one of the following methods:
Including your password entry in the remote system's /etc/passwd file or equivalent network information service map or table
Command |
Description |
ftp |
Accesses the ftp command interpreter. |
ftp remote-system |
Establishes an ftp connection to a remote system. For instructions, see How to Open an ftp Connection to a Remote System. |
open |
Logs in to the remote system from the command interpreter. |
close |
Logs out of the remote system and returns to the command interpreter. |
bye |
Quits the ftp command interpreter. |
help |
Lists all ftp commands or, if a command name is supplied, briefly describes what the command does. |
reset |
Re-synchronizes the command-reply sequencing with the remote ftp server. |
ls |
Lists the contents of the remote working directory. |
pwd |
Displays the name of the remote working directory. |
cd |
Changes the remote working directory. |
lcd |
Changes the local working directory. |
mkdir |
Creates a directory on the remote system. |
rmdir |
Deletes a directory on the remote system. |
get, mget |
Copies a file (or multiple files) from the remote working directory to the local working directory. |
put, mput |
Copies a file (or multiple files) from the local working directory to the remote working directory. |
delete, mdelete |
Deletes a file (or multiple files) from the remote working directory. |
For more information, see ftp(1).
Ensure that you have ftp authentication.
You must have ftp authentication, as described in Authentication for Remote Logins (ftp).
Open a connection to a remote system by using the ftp command.
$ ftp remote-system |
If the connection succeeds, a confirmation message and prompt are displayed.
Type your user name.
Name (remote-system:user-name): user-name |
If prompted, type your password.
331 Password required for user-name: Password: password |
If the system you are accessing has an established anonymous ftp account, you are prompted for an email address for the password. If the ftp interface accepts your password, it displays a confirmation message and the (ftp>) prompt.
You can now use any of the commands that are supplied by the ftp interface, including help. The principal commands are summarized in Table 29–3.
This ftp session was established by the user smith on the remote system pluto:
$ ftp pluto Connected to pluto. 220 pluto FTP server ready. Name (pluto:smith): smith 331 Password required for smith: Password: password 230 User smith logged in. ftp> |
Close an ftp connection to a remote system by using the bye command.
ftp> bye 221-You have transferred 0 bytes in 0 files. 221-Total traffic for this sessions was 172 bytes in 0 transfers. 221-Thanks you for using the FTP service on spdev. 221 Goodbye. |
A goodbye message appears, followed by your usual shell prompt.
Change to a directory on the local system where you want the files from the remote system to be copied.
$ cd target-directory |
Change to the source directory.
ftp> cd source-directory |
If your system is using the automounter, the home directory of the remote system's user appears parallel to yours, under /home.
Ensure that you have read permission for the source files.
ftp> ls -l |
Set the transfer type to binary.
ftp> binary |
To copy a single file, use the get command.
ftp> get filename |
To copy multiple files at once, use the mget command.
ftp> mget filename [filename ...] |
You can supply a series of individual file names and you can use wildcard characters. The mget command copies each file individually, asking you for confirmation each time.
Close the ftp connections.
ftp> bye |
In this example, the user kryten opens an ftp connection to the system pluto, and uses the get command to copy a single file from the /tmp directory.
$ cd $HOME ftp pluto Connected to pluto. 220 pluto FTP server (SunOS 5.8) ready. Name (pluto:kryten): kryten 331 Password required for kryten. Password: xxx 230 User kryten logged in. ftp> cd /tmp 250 CWD command successful. ftp> ls 200 PORT command successful. 150 ASCII data connection for /bin/ls (129.152.221.238,34344) (0 bytes). dtdbcache_:0 filea files ps_data speckeysd.lock 226 ASCII Transfer complete. 53 bytes received in 0.022 seconds (2.39 Kbytes/s) ftp> get filea 200 PORT command successful. 150 ASCII data connection for filea (129.152.221.238,34331) (0 bytes). 221 Goodbye. |
In this example, the same user kryten uses the mget command to copy a set of files from the /tmp directory to his home directory. Note that kryten can accept or reject individual files in the set.
$ ftp> cd /tmp 250 CWD command successful. ftp> ls files 200 PORT command successful. 150 ASCII data connection for /bin/ls (129.152.221.238,34345) (0 bytes). fileb filec filed remote: files 21 bytes received in 0.015 seconds (1.36 Kbytes/s) ftp> cd files 250 CWD command successful. ftp> mget file* mget fileb? y 200 PORT command successful. 150 ASCII data connection for fileb (129.152.221.238,34347) (0 bytes). 226 ASCII Transfer complete. mget filec? y 200 PORT command successful. 150 ASCII data connection for filec (129.152.221.238,34348) (0 bytes). 226 ASCII Transfer complete. mget filed? y 200 PORT command successful. 150 ASCII data connection for filed (129.152.221.238,34351) (0 bytes). 226 ASCII Transfer complete.200 PORT command successful. ftp> bye 221 Goodbye. |
Change to the source directory on the local system.
The directory from which you type the ftp command is the local working directory, and thus the source directory for this operation.
Establish an ftp connection.
Change to the target directory.
ftp> cd target-directory |
Remember, if your system is using the automounter, the home directory of the remote system's user appears parallel to yours, under /home.
Ensure that you have write permission to the target directory.
ftp> ls -l target-directory |
ftp> binary |
To copy a single file, use the put command.
ftp> put filename |
To copy multiple files at once, use the mput command.
ftp> mput filename [filename ...] |
You can supply a series of individual file names and you can use wildcard characters. The mput command copies each file individually, asking you for confirmation each time.
To close the ftp connection, type bye.
ftp> bye |
In this example, the user kryten opens an ftp connection to the system pluto, and uses the put command to copy a file from his or her system to the /tmp directory on system pluto.
$ cd /tmp ftp pluto Connected to pluto. 220 pluto FTP server (SunOS 5.8) ready. Name (pluto:kryten): kryten 331 Password required for kryten. Password: xxx 230 User kryten logged in. ftp> cd /tmp 250 CWD command successful. ftp> put filef 200 PORT command successful. 150 ASCII data connection for filef (129.152.221.238,34356). 226 Transfer complete. ftp> ls 200 PORT command successful. 150 ASCII data connection for /bin/ls (129.152.221.238,34357) (0 bytes). dtdbcache_:0 filea filef files ps_data speckeysd.lock 226 ASCII Transfer complete. 60 bytes received in 0.058 seconds (1.01 Kbytes/s) ftp> bye 221 Goodbye. |
In this example, the same user kryten uses the mput command to copy a set of files from his or her home directory to pluto's /tmp directory. Note that kryten can accept or reject individual files in the set.
$ cd $HOME/testdir $ ls test1 test2 test3 $ ftp pluto Connected to pluto. 220 pluto FTP server (SunOS 5.8) ready. Name (pluto:kryten): kryten 331 Password required for kryten. Password: xxx 230 User kryten logged in. ftp> cd /tmp 250 CWD command successful. ftp> mput test* mput test1? y 200 PORT command successful. 150 ASCII data connection for test1 (129.152.221.238,34365). 226 Transfer complete. mput test2? y 200 PORT command successful. 150 ASCII data connection for test2 (129.152.221.238,34366). 226 Transfer complete. mput test3? y 200 PORT command successful. 150 ASCII data connection for filef (129.152.221.238,34356). 226 Transfer complete. ftp> bye 221 Goodbye. |
