System Administration Guide: Network Services
NFS Files
You need several files to support NFS activities on any computer. Many of these files are ASCII, but some of the files are data files. Table 6–1 lists these files and their functions.
Table 6–1 NFS Files
File Name
Function
/etc/default/autofs
Lists configuration information for the autofs environment.
/etc/default/fs
Lists the default file-system type for local file systems.
/etc/default/nfs
Lists configuration information for lockd and nfsd. For more information, refer to Keywords for the /etc/default/nfs File and the nfs(4) man page.
/etc/default/nfslogd
Lists configuration information for the NFS server logging daemon, nfslogd.
/etc/dfs/dfstab
Lists the local resources to be shared.
/etc/dfs/fstypes
Lists the default file-system types for remote file systems.
/etc/dfs/sharetab
Lists the local and remote resources that are shared. See the sharetab(4) man page. Do not edit this file.
/etc/mnttab
Lists file systems that are currently mounted, including automounted directories. See the mnttab(4) man page. Do not edit this file.
/etc/netconfig
Lists the transport protocols. Do not edit this file.
/etc/nfs/nfslog.conf
Lists general configuration information for NFS server logging.
/etc/nfs/nfslogtab
Lists information for log postprocessing by nfslogd. Do not edit this file.
/etc/nfssec.conf
Lists NFS security services.
/etc/rmtab
Lists file systems that are remotely mounted by NFS clients. See the rmtab(4) man page. Do not edit this file.
/etc/vfstab
Defines file systems to be mounted locally. See the vfstab(4) man page.
The first entry in /etc/dfs/fstypes is often used as the default file-system type for remote file systems. This entry defines the NFS file-system type as the default.
Only one entry is in /etc/default/fs: the default file-system type for local disks. You can determine the file-system types that are supported on a client or server by checking the files in /kernel/fs.
/etc/default/autofs File
Starting in the Solaris 10 release, you can use the /etc/default/autofs file to configure your autofs environment. Specifically, this file provides an additional way to configure your autofs commands and autofs daemons. The same specifications you would make on the command line can be made in this configuration file. However, unlike the specifications you would make on the command line, this file preserves your specifications, even during upgrades to your operating system. Additionally, you are no longer required to update critical startup files to ensure that the existing behavior of your autofs environment is preserved. You can make your specifications by providing values for the following keywords:
AUTOMOUNT_TIMEOUT
Sets the duration for a file system to remain idle before the file system is unmounted. This keyword is the equivalent of the -t argument for the automount command. The default value is 600.
AUTOMOUNT_VERBOSE
Provides notification of autofs mounts, unmounts, and other nonessential events. This keyword is the equivalent of the -v argument for automount. The default value is FALSE.
AUTOMOUNTD_VERBOSE
Logs status messages to the console and is the equivalent of the -v argument for the automountd daemon. The default value is FALSE.
AUTOMOUNTD_NOBROWSE
Turns browsing on or off for all autofs mount points and is the equivalent of the -n argument for automountd. The default value is FALSE.
AUTOMOUNTD_TRACE
Expands each remote procedure call (RPC) and displays the expanded RPC on standard output. This keyword is the equivalent of the -T argument for automountd. The default value is 0. Values can range from 0 to 5.
AUTOMOUNTD_ENV
Permits you to assign different values to different environments. This keyword is the equivalent of the -D argument for automountd. The AUTOMOUNTD_ENV keyword can be used multiple times. However, you must use separate lines for each environment assignment.
For more information, refer to the man pages for automount(1M) and automountd(1M). For procedural information, refer to How to Use the /etc/default/autofs File.
In NFS version 4, the following keywords can be set in the /etc/default/nfs file. These keywords control the NFS protocols that are used by both the client and server.
NFS_SERVER_VERSMIN
Sets the minimum version of the NFS protocol to be registered and offered by the server. Starting in the Solaris 10 release, the default is 2. Other valid values include 3 or 4. Refer to Setting Up NFS Services.
NFS_SERVER_VERSMAX
Sets the maximum version of the NFS protocol to be registered and offered by the server. Starting in the Solaris 10 release, the default is 4. Other valid values include 2 or 3. Refer to Setting Up NFS Services.
NFS_CLIENT_VERSMIN
Sets the minimum version of the NFS protocol to be used by the NFS client. Starting in the Solaris 10 release, the default is 2. Other valid values include 3 or 4. Refer to Setting Up NFS Services.
NFS_CLIENT_VERSMAX
Sets the maximum version of the NFS protocol to be used by the NFS client. Starting in the Solaris 10 release, the default is 4. Other valid values include 2 or 3. Refer to Setting Up NFS Services.
NFS_SERVER_DELEGATION
Controls whether the NFS version 4 delegation feature is enabled for the server. If this feature is enabled, the server attempts to provide delegations to the NFS version 4 client. By default, server delegation is enabled. To disable server delegation, see How to Select Different Versions of NFS on a Server. For more information, refer to Delegation in NFS Version 4.
NFSMAPID_DOMAIN
Sets a common domain for clients and servers. Overrides the default behavior of using the local DNS domain name. For task information, refer to Setting Up NFS Services. Also, see nfsmapid Daemon.
/etc/default/nfslogd File
This file defines some of the parameters that are used when using NFS server logging. The following parameters can be defined.
CYCLE_FREQUENCY
Determines the number of hours that must pass before the log files are cycled. The default value is 24 hours. This option is used to prevent the log files from growing too large.
IDLE_TIME
Sets the number of seconds nfslogd should sleep before checking for more information in the buffer file. This parameter also determines how often the configuration file is checked. This parameter, along with MIN_PROCESSING_SIZE, determines how often the buffer file is processed. The default value is 300 seconds. Increasing this number can improve performance by reducing the number of checks.
MAPPING_UPDATE_INTERVAL
Specifies the number of seconds between updates of the records in the file-handle-to-path mapping tables. The default value is 86400 seconds or one day. This parameter helps keep the file-handle-to-path mapping tables up-to-date without having to continually update the tables.
MAX_LOGS_PRESERVE
Determines the number of log files to be saved. The default value is 10.
MIN_PROCESSING_SIZE
Sets the minimum number of bytes that the buffer file must reach before processing and writing to the log file. This parameter, along with IDLE_TIME, determines how often the buffer file is processed. The default value is 524288 bytes. Increasing this number can improve performance by reducing the number of times the buffer file is processed.
PRUNE_TIMEOUT
Selects the number of hours that must pass before a file-handle-to-path mapping record times out and can be reduced. The default value is 168 hours or 7 days.
UMASK
Specifies the file mode creation mask for the log files that are created by nfslogd. The default value is 0137.
/etc/nfs/nfslog.conf File
This file defines the path, file names, and type of logging to be used by nfslogd. Each definition is associated with a tag. Starting NFS server logging requires that you identify the tag for each file system. The global tag defines the default values. You can use the following parameters with each tag as needed.
defaultdir=path
Specifies the default directory path for the logging files. Unless you specify differently, the default directory is /var/nfs.
log=path/filename
Sets the path and file name for the log files. The default is /var/nfs/nfslog.
fhtable=path/filename
Selects the path and file name for the file-handle-to-path database files. The default is /var/nfs/fhtable.
buffer=path/filename
Determines the path and file name for the buffer files. The default is /var/nfs/nfslog_workbuffer.
logformat=basic|extended
Selects the format to be used when creating user-readable log files. The basic format produces a log file that is similar to some ftpd daemons. The extended format gives a more detailed view.
If the path is not specified, the path that is defined by defaultdir is used. Also, you can override defaultdir by using an absolute path.
To identify the files more easily, place the files in separate directories. Here is an example of the changes that are needed.
% cat /etc/nfs/nfslog.conf
#ident  "@(#)nfslog.conf        1.5     99/02/21 SMI"
# NFS server log configuration file.
global  defaultdir=/var/nfs \
        log=nfslog fhtable=fhtable buffer=nfslog_workbuffer
publicftp log=logs/nfslog fhtable=fh/fhtables buffer=buffers/workbuffer
In this example, any file system that is shared with log=publicftp uses the following values:
For procedural information, refer to How to Enable NFS Server Logging.
