The ip token contains a copy of an Internet Protocol header. The ip token has two fields:
A token ID that identifies this token as an ip token
A copy of the IP header, that is, all 20 bytes
The praudit command displays the ip token as follows:
ip address,0.0.0.0 |
The IP header structure is defined in the /usr/include/netinet/ip.h file.
