Access rights, whether specified in an environment variable or a command, are identified with three types of arguments: class, operator, and right.
Class. Class refers to the type of NIS+ principal (authorization class) to which the rights will apply.
| Class | Description |
| n | Nobody: all unauthenticated requests |
| o | The owner of the object or table entry |
| g | The group owner of the object or table entry |
| w | World: all authenticated principals |
| a | All: shorthand for owner, group, and world (this is the default) |
Operator. The operator indicates the kind of operation that will be performed with the rights.
| Operator | Description |
| + | Adds the access rights specified by right |
| - | Revokes the access rights specified by right |
| = | Explicitly changes the access rights specified by right; in other words, revokes all existing rights and replaces them with the new access rights. |
Rights. The rights are the access rights themselves. The accepted values for each are listed below.
| Right | Description |
| r | Reads the object definition or table entry |
| m | Modifies the object definition or table entry |
| c | Creates a table entry or column |
| d | Destroys a table entry or column |
You can combine operations on a single command line by separating each operation from the next with a comma (,).
Table 15–7 NIS+ Class, Operator, and Rights Syntax – Examples| Operations | Syntax |
| Add read access rights to the owner class | o+r |
| Change owner. group, and world classes' access rights to modify only from whatever they were before | a=m |
| Add read and modify rights to the world and nobody classes | wn+m |
| Remove all four rights from the group, world, and nobody classes | gwn-rmcd |
| Add create and destroy rights to the owner class and add read and modify rights to the world and nobody classes | o+cd,wn+rm |
