Device attribute information can be represented by a name-value pair notation called a property.
For example, device registers and onboard memory can be represented by the reg property. The reg property is a software abstraction that describes device hardware registers. The value of the reg property encodes the device register address location and size. Drivers use the reg property to access device registers.
Another example is the interrupt property. An interrupt property represents the device interrupt. The value of the interrupt property encodes the device-interrupt PIN.
Five types of values can be assigned to properties:
Byte array – Series of bytes of an arbitrary length
Integer property – An integer value
Integer array property – An array of integers
String property – A null-terminated string
String array property – A list of null-terminated strings
A property that has no value is considered to be a Boolean property. A Boolean property that exists is true. A Boolean value that does not exist is false.
Strictly speaking, DDI/DKI software property names have no restrictions. Certain uses are recommended, however. The IEEE 1275-1994 Standard for Boot Firmware defines properties as follows:
A property is a human readable text string consisting of from 1 to 31 printable characters. Property names cannot contain upper case characters or the characters “/”, “\”, “:”, “[“, “]” and “@”. Property names beginning with the character “+” are reserved for use by future revisions of IEEE 1275-1994.
By convention, underscores are not used in property names. Use a hyphen (-) instead. By convention, property names ending with the question mark character (?) contain values that are strings, typically TRUE or FALSE, for example auto-boot?.
Predefined property names are listed in publications of the IEEE 1275 Working Group. See http://playground.sun.com/1275/ for information about how to obtain these publications. For a discussion of adding properties in driver configuration files, see the driver.conf(4) man page. The pm(9P) and pm-components(9P) man pages show how properties are used in power management. Read the sd(7D) man page as an example of how properties should be documented in device driver man pages.
To create a property for a driver, or to update an existing property, use an interface from the DDI driver update interfaces such as ddi_prop_update_int(9F) or ddi_prop_update_string(9F) with the appropriate property type. See Table 4–1 for a list of available property interfaces. These interfaces are typically called from the driver's attach(9E) entry point. In the following example, ddi_prop_update_string()creates a string property called pm-hardware-state with a value of needs-suspend-resume.
/* The following code is to tell cpr that this device
* needs to be suspended and resumed.
(void) ddi_prop_update_string(device, dip,
"pm-hardware-state", "needs-suspend-resume");
In most cases, using a ddi_prop_update() routine is sufficient for updating a property. Sometimes, however, the overhead of updating a property value that is subject to frequent change can cause performance problems. See prop_op() Entry Point for a description of using a local instance of a property value to avoid using ddi_prop_update().
A driver can request a property from its parent, which in turn can ask its parent. The driver can control whether the request can go higher than its parent.
For example, the esp driver in the following example maintains an integer property called targetx-sync-speed for each target. The x in targetx-sync-speed represents the target number. The prtconf(1M) command displays driver properties in verbose mode. The following example shows a partial listing for the esp driver.
% prtconf -v
esp, instance #0
Driver software properties:
name <target2-sync-speed> length <4>
value <0x00000fa0>.
The following table provides a summary of the property interfaces.
Table 4–1 Property Interface Uses|
Family |
Property Interfaces |
Description |
ddi_prop_lookup |
Looks up a property and returns successfully if the property exists. Fails if the property does not exist |
Looks up and returns an integer property |
Looks up and returns a 64-bit integer property |
Looks up and returns an integer array property |
Looks up and returns a 64-bit integer array property |
Looks up and returns a string property |
Looks up and returns a string array property |
Looks up and returns a byte array property |
ddi_prop_update |
Updates or creates an integer property |
Updates or creates a single 64-bit integer property |
Updates or creates an integer array property |
Updates or creates a string property |
Updates or creates a string array property |
Updates or creates a 64-bit integer array property |
Updates or creates a byte array property |
ddi_prop_remove |
Removes a property |
Removes all properties that are associated with a device |
Whenever possible, use 64-bit versions of int property interfaces such as ddi_prop_update_int64(9F) instead of 32-bit
versions such as ddi_prop_update_int(9F)).
The prop_op(9E) entry point is generally required for reporting device properties or driver properties to the system. If the driver does not need to create or manage its own properties, then the ddi_prop_op(9F) function can be used for this entry point.
ddi_prop_op(9F) can be used as the prop_op(9E) entry point for a device driver when ddi_prop_op() is defined in the driver's cb_ops(9S) structure. ddi_prop_op() enables a leaf device to search for and obtain property values from the device's property list.
If the driver has to maintain a property whose value changes frequently, you should define a driver-specific prop_op() routine within the cb_ops structure instead of calling ddi_prop_op(). This technique avoids the inefficiency of using ddi_prop_update() repeatedly. The driver should then maintain a copy of the property value either within its soft-state structure or in a driver variable.
The prop_op(9E) entry point reports the values of specific driver properties and device properties to the system. In many cases, the ddi_prop_op(9F) routine can be used as the driver's prop_op() entry point in the cb_ops(9S) structure. ddi_prop_op() performs all of the required processing. ddi_prop_op() is sufficient for drivers that do not require special processing when handling device property requests.
However, sometimes the driver must provide a prop_op() entry point. For example, if a driver maintains a property whose value changes frequently, updating the property with ddi_prop_update(9F) for each change is not efficient. Instead, the driver should maintain a shadow copy of the property in the instance's soft state. The driver would then update the shadow copy when the value changes without using any of the ddi_prop_update() routines. The prop_op() entry point must intercept requests for this property and use one of the ddi_prop_update() routines to update the value of the property before passing the request to ddi_prop_op() to process the property request.
In the following example, prop_op() intercepts requests for the temperature property. The driver updates a variable in the state structure whenever the property changes. However, the property is updated only when a request is made. The driver then uses ddi_prop_op() to process the property request. If the property request is not specific to a device, the driver does not intercept the request. This situation is indicated when the value of the dev parameter is equal to DDI_DEV_T_ANY, the wildcard device number.
static int
xx_prop_op(dev_t dev, dev_info_t *dip, ddi_prop_op_t prop_op,
int flags, char *name, caddr_t valuep, int *lengthp)
minor_t instance;
struct xxstate *xsp;
if (dev != DDI_DEV_T_ANY) {
return (ddi_prop_op(dev, dip, prop_op, flags, name,
valuep, lengthp));
instance = getminor(dev);
xsp = ddi_get_soft_state(statep, instance);
if (xsp == NULL)
return (DDI_PROP_NOTFOUND);
if (strcmp(name, "temperature") == 0) {
ddi_prop_update_int(dev, dip, name, temperature);
/* other cases */
