This section describes various types of GSS-API data types and values. Some data types, such as gss_cred_id_t or gss_name_t, are opaque to the user. These data types do not need to be discussed. This section explains the following topics:
Basic GSS-API Data Types –
Shows the definitions of the OM_uint32, gss_buffer_desc, gss_OID_desc, gss_OID_set_desc_struct,
and gss_channel_bindings_struct data types.
Name Types – Shows the various name formats recognized by the GSS-API for specifying names.
Address Types for Channel Bindings – Shows the various values that can be used as the initiator_addrtype and acceptor_addrtype fields of the gss_channel_bindings_t structure.
This section describes data types that are used by GSS-API.
OM_uint32
The OM_uint32 is a platform-independent 32-bit unsigned
integer.
The definition of the gss_buffer_desc with
the gss_buffer_t pointer takes the following form:
typedef struct gss_buffer_desc_struct {
size_t length;
void *value;
} gss_buffer_desc, *gss_buffer_t;
The definition of the gss_OID_desc with the gss_OID pointer takes the following form:
typedef struct gss_OID_desc_struct {
OM_uint32 length;
void*elements;
} gss_OID_desc, *gss_OID;
The definition of the gss_OID_set_desc with
the gss_OID_set pointer takes the following form:
typedef struct gss_OID_set_desc_struct {
size_t count;
gss_OID elements;
} gss_OID_set_desc, *gss_OID_set;
The definition of the gss_channel_bindings_struct structure and the gss_channel_bindings_t pointer has the following form:
typedef struct gss_channel_bindings_struct {
OM_uint32 initiator_addrtype;
gss_buffer_desc initiator_address;
OM_uint32 acceptor_addrtype;
gss_buffer_desc acceptor_address;
gss_buffer_desc application_data;
} *gss_channel_bindings_t;
A name type indicates the format of the associated name. See Names in GSS-API and GSS-API OIDs for more on names and name types. The GSS-API supports the gss_OID name types in the following table.
The symbolic name GSS_C_NO_NAME is recommended as a parameter value to indicate that no value is supplied in the transfer of names.
This value corresponds to a null input value instead of an actual object identifier. Where specified, the value indicates interpretation of an associated name that is based on a mechanism-specific default printable syntax.
A means to identify anonymous names. This value can be compared with to determine in a mechanism-independent fashion whether a name refers to an anonymous principal.
A name that has been exported with the gss_export_name() function.
Used to represent services that are associated with host computers. This name form is constructed using two elements, service and hostname, as follows: service@hostname.
Used to indicate a numeric user identifier corresponding to a user on a local system. The interpretation of this value is OS-specific. The gss_import_name() function resolves this UID into a user name, which is then treated as the User Name Form.
Used to indicate a string of digits that represents the numeric user identifier of a user on a local system. The interpretation of this value is OS-specific. This name type is similar to the Machine UID Form, except that the buffer contains a string that represents the user ID.
A named user on a local system. The interpretation of this value is OS-specific. The value takes the form: username.
The following table shows the possible values for the initiator_addrtype and acceptor_addrtype fields of the gss_channel_bindings_struct structure. These fields indicate the format that a name can take, for example, ARPAnet IMP address or AppleTalk address. Channel bindings are discussed in Using Channel Bindings in GSS-API.
Table B–4 Channel Binding Address Types|
Field |
Value (Decimal) |
Address Type |
GSS_C_AF_UNSPEC |
0 |
Unspecified address type |
GSS_C_AF_LOCAL |
1 |
Host-local |
GSS_C_AF_INET |
2 |
Internet address type, for example, IP |
GSS_C_AF_IMPLINK |
3 |
ARPAnet IMP |
GSS_C_AF_PUP |
4 |
pup protocols, for example, BSP |
GSS_C_AF_CHAOS |
5 |
MIT CHAOS protocol |
GSS_C_AF_NS |
6 |
XEROX NS |
GSS_C_AF_NBS |
7 |
nbs |
GSS_C_AF_ECMA |
8 |
ECMA |
GSS_C_AF_DATAKIT |
9 |
Datakit protocols |
GSS_C_AF_CCITT |
10 |
CCITT |
GSS_C_AF_SNA |
11 |
IBM SNA |
GSS_C_AF_DECnet |
12 |
DECnet |
GSS_C_AF_DLI |
13 |
Direct data link interface |
GSS_C_AF_LAT |
14 |
LAT |
GSS_C_AF_HYLINK |
15 |
NSC Hyperchannel |
GSS_C_AF_APPLETALK |
16 |
AppleTalk |
GSS_C_AF_BSC |
17 |
BISYNC |
GSS_C_AF_DSS |
18 |
Distributed system services |
GSS_C_AF_OSI |
19 |
OSI TP4 |
GSS_C_AF_X25 |
21 |
X.25 |
GSS_C_AF_NULLADDR |
255 |
No address specified |
