Name | Synopsis | Description | Options | Environment Variables | Exit Status | Files | Attributes | See Also
/usr/bin/imqadmin [-javahome path]
/usr/bin/imqadmin -h
/usr/bin/imqadmin -v
imqadmin launches the graphical user interface application that performs most Message Queue administration tasks. These tasks include managing broker instances (including physical destinations) and administered objects.
The following options are supported:
Display usage help. The application is not launched.
Specify a path to an alternate Java 2 compatible runtime.
Display version information.
The following environment variables affect the execution of this command:
Specify the Java 2 compatible runtime. When this environment variable is not set it defaults to /usr/j2se.
Contains user settings, a list of broker instances being managed.
Contains user settings, a list of object stores being managed.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWiqu |
imqbrokerd(1M), imqcmd(1M), imqdbmgr(1M), imqkeytool(1M), imqobjmgr(1M), imqusermgr(1M), attributes(5)
Sun Java System Message Queue Administrator's Guide
