Name | Synopsis | Description | Options | Environment Variables | Exit Status | Files | Attributes | See Also
/usr/bin/imqkeytool [-broker] [-servlet keystore_location]
/usr/bin/imqkeytool -h
The imqkeytool utility generates a self-signed certificate for secure communication. The certificate can be used by a broker instance to establish a secure connection with a client, or by a Message Queue-supplied HTTPS servlet to establish a secure connection with a broker instance. An HTTPS servlet is an SSL-enabled varient of the HyperText Transfer Protocol that establishes a secure connection with a broker instance.
Without an option, imqkeytool generates a self-signed certificate for a broker instance.
imqkeytool uses command line options to specify whether the certificate is used by a broker instance or by a servlet.
The following options are supported:
Generate a self-signed certificate for the broker and places it in the Message Queue keystore. All broker instances running on a system must use the same certificate.
Display usage help. Do not execute anything else on the command line.
Generate a self-signed certificate for an HTTPS servlet and places it in keystore_location.
keystore_location refers to the location of the keystore. You should move this keystore to a location where it is accessible and readable by the Message Queue HTTPS servlet to establish a secure connection with a broker.
The following environment variables affect the execution of this command:
Specify the Java 2 compatible runtime. When this environment variable is not set it defaults to /usr/j2se.
Contains Message Queue keystore in which imqkeytool stores a self-signed certificate for brokers.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWiqu |
imqadmin(1M), imqbrokerd(1M), imqcmd(1M), imqdbmgr(1M), imqobjmgr(1M), imqusermgr(1M), attributes(5)
Sun Java System Message Queue Administrator's Guide
