Name | Synopsis | Parameters | Description | Return Values | Errors | Attributes | See Also | Notes
cc [flag...] file... -lX11 -lXtsol [library...] #include <X11/extensions/Xtsol.h> Status XTSOLgetPropLabel(display, window, property, sl); Display *display; Window window; Atom property; m_label_t *sl;
Specifies a pointer to the Display structure; returned from XOpenDisplay().
Specifies the ID of the window whose property's label you want to get.
Specifies the property atom.
Returns a sensitivity label that is the current label of the specified property.
Client requires the PRIV_WIN_DAC_READ and PRIV_WIN_MAC_READ privileges. The XTSOLgetPropLabel() function retrieves the sensitivity label that is associated with a property hanging on a window.
None.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
Unsafe |
libXtsol(3LIB), XTSOLgetPropAttributes(3XTSOL), XTSOLsetPropLabel(3XTSOL), attributes(5)
Setting Window Polyinstantiation Information in Solaris Trusted Extensions Developer’s Guide
The functionality described on this manual page is available only if the system is configured with Trusted Extensions.
