Name | Synopsis | Interface Level | Parameters | Description | Structure Members | Return Values | Context | See Also
#include <sys/pccard.h>
int32_t csx_ParseTuple(client_handle_t ch, tuple_t *tu, cisparse_t *cp,
cisdata_t cd);
Solaris DDI Specific (Solaris DDI)
Client handle returned from csx_RegisterClient(9F).
Pointer to a tuple_t structure (see tuple(9S)) returned by a call to csx_GetFirstTuple(9F) or csx_GetNextTuple(9F).
Pointer to a cisparse_t structure that unifies all tuple parsing structures.
Extended tuple data for some tuples.
This function is the generic tuple parser entry point.
typedef union cisparse_t {
cistpl_config_t cistpl_config;
cistpl_device_t cistpl_device;
cistpl_vers_1_t cistpl_vers_1;
cistpl_vers_2_t cistpl_vers_2;
cistpl_jedec_t cistpl_jedec;
cistpl_format_t cistpl_format;
cistpl_geometry_t cistpl_geometry;
cistpl_byteorder_t cistpl_byteorder;
cistpl_date_t cistpl_date;
cistpl_battery_t cistpl_battery;
cistpl_org_t cistpl_org;
cistpl_manfid_t cistpl_manfid;
cistpl_funcid_t cistpl_funcid;
cistpl_funce_t cistpl_funce;
cistpl_cftable_entry_t cistpl_cftable_entry;
cistpl_linktarget_t cistpl_linktarget;
cistpl_longlink_ac_t cistpl_longlink_ac;
cistpl_longlink_mfc_t cistpl_longlink_mfc;
cistpl_spcl_t cistpl_spcl;
cistpl_swil_t cistpl_swil;
cistpl_bar_t cistpl_bar;
cistpl_devicegeo_t cistpl_devicegeo;
cistpl_longlink_cb_t cistpl_longlink_cb;
cistpl_get_tuple_name_t cistpl_get_tuple_name;
} cisparse_t;
Successful operation.
Client handle is invalid.
Parser does not know how to parse tuple.
No PC Card in socket.
Generic parser error.
No Card Information Structure (CIS) on PC Card.
No PCMCIA hardware installed.
This function may be called from user or kernel context.
csx_GetFirstTuple(9F), csx_GetTupleData(9F), csx_Parse_CISTPL_BATTERY(9F), csx_Parse_CISTPL_BYTEORDER(9F), csx_Parse_CISTPL_CFTABLE_ENTRY(9F), csx_Parse_CISTPL_CONFIG(9F), csx_Parse_CISTPL_DATE(9F), csx_Parse_CISTPL_DEVICE(9F), csx_Parse_CISTPL_FUNCE(9F), csx_Parse_CISTPL_FUNCID(9F), csx_Parse_CISTPL_JEDEC_C(9F), csx_Parse_CISTPL_MANFID(9F), csx_Parse_CISTPL_SPCL(9F), csx_Parse_CISTPL_VERS_1(9F), csx_Parse_CISTPL_VERS_2(9F), csx_RegisterClient(9F), csx_ValidateCIS(9F), tuple(9S)
PC Card 95 Standard, PCMCIA/JEIDA
