Name | Synopsis | Interface Level | Parameters | Description | Return Values | Context | See Also
#include <sys/ddi.h>
#include <sys/sunddi.h>
int ddi_dma_getwin(ddi_dma_handle_t handle, uint_t win,
off_t *offp, size_t *lenp, ddi_dma_cookie_t *cookiep,
uint_t *ccountp);
Solaris DDI specific (Solaris DDI).
The DMA handle previously allocated by a call to ddi_dma_alloc_handle(9F).
Number of the window to activate.
Pointer to an offset. Upon a successful return, offp will contain the new offset indicating the beginning of the window within the object.
Upon a successful return, lenp will contain the size, in bytes, of the current window.
A pointer to the first ddi_dma_cookie(9S) structure.
Upon a successful return, ccountp will contain the number of cookies for this DMA window.
ddi_dma_getwin() activates a new DMA window. If a DMA resource allocation request returns DDI_DMA_PARTIAL_MAP indicating that resources for less than the entire object were allocated, the current DMA window can be changed by a call to ddi_dma_getwin().
The caller must first determine the number of DMA windows, N, using ddi_dma_numwin(9F). ddi_dma_getwin() takes a DMA window number from the range [0..N-1] as the parameter win and makes it the current DMA window.
ddi_dma_getwin() fills in the first DMA cookie pointed to by cookiep with the appropriate address, length, and bus type. *ccountp is set to the number of DMA cookies representing this DMA object. Subsequent DMA cookies must be retrieved using ddi_dma_nextcookie(9F).
ddi_dma_getwin() takes care of underlying resource synchronizations required to shift the window. However accessing the data prior to or after moving the window requires further synchronization steps using ddi_dma_sync(9F).
ddi_dma_getwin() is normally called from an interrupt routine. The first invocation of the DMA engine is done from the driver. All subsequent invocations of the DMA engine are done from the interrupt routine. The interrupt routine checks to see if the request has been completed. If it has, the interrupt routine returns without invoking another DMA transfer. Otherwise, it calls ddi_dma_getwin() to shift the current window and start another DMA transfer.
ddi_dma_getwin() returns:
Resources for the specified DMA window are allocated.
win is not a valid window index.
ddi_dma_getwin() can be called from user, kernel, or interrupt context.
ddi_dma_addr_bind_handle(9F), ddi_dma_alloc_handle(9F), ddi_dma_buf_bind_handle(9F), ddi_dma_nextcookie(9F), ddi_dma_numwin(9F), ddi_dma_sync(9F), ddi_dma_unbind_handle(9F), ddi_dma_cookie(9S)
