The following table describes the menu items (and their default values) when you set up a terminal by using the Serial Ports tool.
Table 2–1 Terminal Default Values
Detail |
Item |
Default Value |
Basic |
Port | |
Description |
Terminal |
Service Status |
Enabled |
Baud Rate |
9600 |
Terminal Type |
vi925 |
Login Prompt |
ttyn login: |
Advanced |
Carrier Detection |
Software |
Option: Connect on Carrier |
Not available |
Option: Bidirectional |
Available |
Option: Initialize Only |
Not available |
Timeout (seconds) |
Never |
Port Monitor |
zsmon |
Service Program |
/usr/bin/login |
