The following table describes the three modem templates that are available when you set up a modem using the Serial Ports tool.
Table 2–2 Modem Templates
Modem Configuration |
Description |
Dial-In Only |
Users can dial in to the modem but cannot dial out. |
Dial-Out Only |
Users can dial out from the modem but cannot dial in. |
Dial-In and Out (Bidirectional) |
Users can either dial in or dial out from the modem. |
The following table describes the default values of each template.
Table 2–3 Modem Template Default Values
Detail |
Item |
Modem - Dial-In Only |
Modem - Dial-Out Only |
Modem - Dial In and Out |
Basic |
Port Name | |||
Description |
Modem – Dial In Only |
Modem – Dial Out Only |
Modem – Dial In and Out |
Service Status |
Enabled |
Enabled |
Enabled |
Baud Rate |
9600 |
9600 |
9600 |
Login Prompt |
ttyn login: |
ttyn login: |
ttyn login: |
Advanced |
Carrier Detection |
Software |
Software |
Software |
Option: Connect on Carrier |
Not available |
Not available |
Not available |
Option: Bidirectional |
Not available |
Not available |
Available |
Option: Initialize Only |
Not available |
Available |
Not available |
Timeout (seconds) |
Never |
Never |
Never |
Port Monitor |
zsmon |
zsmon |
zsmon |
Service Program |
/usr/bin/login |
/usr/bin/login |
/usr/bin/login |
The following table describes the default values for the Initialize Only template.
Table 2–4 Initialize Only - No Connection Default Values
Detail |
Item |
Default Value |
Basic |
Port Name |
Description |
Initialize Only - No Connection |
Service Status |
Enabled |
Baud Rate |
9600 |
Login Prompt |
ttyn login: |
Advanced |
Carrier Detection |
Software |
Not available |
Available |
Available |
Timeout (seconds) |
Never |
Port Monitor |
zsmon |
Service Program |
/usr/bin/login |
