Starting with the Solaris 10 1/06 release, use this procedure to add a diskless client after you have added OS services.
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Add the diskless client.
# /usr/sadm/bin/smdiskless add -- -i ip-address -e ethernet-address -n client-name -x os= instruction-set.machine-class.Solaris_ version -x root=/export/root/client-name -x swap=/export/swap/client-name -x swapsize=size -x tz= time-zone -x locale= locale-name |
Adds the specified diskless client.
Identifies that the subcommand arguments start after this point.
Identifies the IP address of the diskless client.
Identifies the Ethernet address of the diskless client.
Specifies the name of the diskless client.
Specifies the instruction architecture, machine class, OS, and the Solaris version for the diskless client.
Identifies the root (/) directory for the diskless client.
Identifies the swap file for the diskless client.
Specifies the size of the swap file in Mbytes. The default is 24 Mbytes.
Specifies the time-zone for the diskless client.
Specifies the locale to install for the diskless client.
For more information, see the smdiskless(1M) man page.
If not already created, add the BootSrva and BootFile DHCP options to your DHCP server configuration to enable a PXE boot.
For example:
Boot server IP (BootSrvA) : svr-addr Boot file (BootFile) : 01client-macro |
where svr-addr is the IP address of the server and client-macro is named by the client's Ethernet type (01) and the MAC address of the client. This number is also the name of the file that is used in the /tftpboot directory on the installation server.
The client-macro notation consists of uppercase letters. The notation should not contain any colons.
The following files and directories are created in the /tftpboot directory:
drwxr-xr-x 6 root sys 512 Dec 28 14:53 client-host-name lrwxrwxrwx 1 root root 31 Dec 28 14:53 menu.lst.01ethernet-address -> /tftpboot/client-host-name/grub/menu.lst -rw-r--r-- 1 root root 118672 Dec 28 14:53 01ethernet-address |
If the console is on a serial port, edit the /tftpboot/menu.lst.01 ethernet-address file to uncomment the line that specifies the tty setting.
To change the default menu.lst file that is created on the client, edit the echo lines in the /usr/sadm/lib/wbem/config_tftp file.
For more information, see Booting an x86 Based System from the Network.
Verify that the diskless clients were installed.
# /usr/sadm/bin/smdiskless list -H host-name:898 -- |
(Optional) Continue to use the smdiskless add command to add each diskless client.
This example shows how to add a Solaris 10 x86 based diskless client, mikey1.
rainy-01# /usr/sadm/bin/smdiskless add -H sdts-01-qfe0 -- -o sdts-01-qfe0 -n mikey1 -i 192.168.20.22 -e 00:E0:88:55:33:BC -x os=i386.i86pc.Solaris_10 -x root=/export/root/mikey1 -x swap=/export/swap/mikey1 Loading Tool: com.sun.admin.osservermgr.cli.OsServerMgrCli from sdts-01-qfe0 Login to rainy-01-qfe0 as user root was successful. Download of com.sun.admin.osservermgr.cli.OsServerMgrCli from rainy-01-qfe0 was successful. # /usr/sadm/bin/smdiskless list -H mikey1:898 -- Loading Tool: com.sun.admin.osservermgr.cli.OsServerMgrCli from mikey1:898 Login to mikey1 as user root was successful. Download of com.sun.admin.osservermgr.cli.OsServerMgrCli from mikey1:898 was successful. Platform -------------------------------------------------------------------------------- i386.i86pc.Solaris_10 sparc.sun4us.Solaris_10 sparc.sun4u.Solaris_10 i386.i86pc.Solaris_9 |
This example shows how to add the BootSrva and BootFile DHCP options that are necessary for enabling a PXE boot.
rainy-01# pntadm -A mikey1 -m 0100E0885533BC -f 'MANUAL+PERMANENT' \ -i 0100E0885533BC 192.168.0.101 |
rainy-01# dhtadm -A -m 0100E0885533BC -d \ ":BootSrvA=192.168.0.1:BootFile=0100E0885533BC:" |
In the preceding examples, the server address is the IP address of the server, and the client macro is named by the client's Ethernet type (01) and its MAC address. This number is also the name of the file that is used in the /tftpboot directory on the installation server. Note that the notation for the client macro consists of uppercase letters and should not contain any colons.
