This section describes functions for wide character and string input and output, character classification, and conversion functions for the Korean character sets. Asian Solaris software implements a wide character library for handling Korean character codes according to industry standards.
Routines that have Korean language-specific dependency are in their own language-specific library, which is linked with the corresponding C compiler option. In Korean Solaris, libkle is linked with -lkle. Refer to the appropriate man page for more information.
Asian Solaris software defines WC as a constant-width, four-byte code. WC uses the ANSI C data type wchar_t, which the Solaris software defines in wchar.h as shown in the following example.
typedef long wchar_h; |
In Solaris software, long is four bytes.
The conversion utilities described in this section are available, but you should use iconv() as a standard function.
Asian Solaris software provides facilities for various conversions.
Character conversion within a code set, such as converting uppercase ASCII to lowercase.
Conversions between different conventions of the national standard character sets.
Conversions between Combination code and Completion code of KS C 5601-1987 and KS C 5601-1992 characters sets.
Conversions between GB and EUC.
Conversions between CNS 11643 code and Big5.
Conversions between code formats such as EUC and WC.
Programs that use the general multibyte conversion utilities should include the header files widec.h and wctype.h. Korean Solaris specific routines (such as iskxxx) are declared in ko/xctype.h.
Programs that use the general multibyte conversion utilities should include three header files: wctype.h, widec.h, andko/xctype.h.
The multibyte conversion functions are similar to the one-byte conversion functions toupper() and tolower(). These functions convert wide-characters to other wide characters. For more information on conversion routines, see the man pages for wconv(3) for all locales and kconv(3) for Korean.
The following routines perform character-based code conversion on the KS C 5601 character set. They convert characters in the set between Completion code (or EUC format) and Combination code (or Packed code). To use these routines, the library kle must be linked using the C compiler option -lkle. For more information, see the kconv(3x) man page.
Table A–2 Korean Code Conversion Functions|
Function |
Description |
comptopack() |
Converts a character in Completion code to Combination (packed) code of KS C 5601-1987. |
packtocomp() |
Converts a character in Combination (Packed) code of KS C 5601-1987 to Completion code. |
wasuntojohap() |
Converts a character in Completion code to Combination (Packed) code of KS C 5601-1992. |
packtocomp() |
Converts a character in Combination (Packed) code of KS C 5601-1992 to Completion code. |
