The Solaris system builds inherent internationalization features into every localized product. Localization facilities support the ANSI C recommendations for internationalization and localization that define the locale and related categories.
A locale contains the culturally specific information and conventions of the language for a particular global region. Each process in the Solaris Operating System has the following set of locale attributes:
Locale settings, which provide the locale and setlocale commands you use to list and set attributes before you start a process from the command line.
For example, the Traditional Chinese locales and the English/ASCII locale both have a category that defines the display of time and date according to the cultural format, as well as the actual Traditional Chinese or English/ASCII characters for the time and date.
Code Sets, which support coding conventions for the CNS11643 and BIG5 character sets. These sets enable you to input, display, and print Traditional Chinese text in file names, system messages, and terminal (TTY), email, and data file content.
htt input method server, which handles Traditional Chinese input for the Solaris Operating System. The htt server receives your keyboard input and converts it to Traditional Chinese characters that are used in Traditional Chinese applications.
The Traditional Chinese Solaris Operating System provides simultaneous support for the locales in the following table . The locales look the same to the end user, but the internal character encoding is different.
Table 1–1 Traditional Chinese Locales
Locale |
Description |
zh_TW.EUC (zh_TW) |
Traditional Chinese EUC locale (CNS11643-1992) |
zh_TW.BIG5 |
Traditional Chinese BIG5 |
zh_TW.UTF-8 |
Traditional Chinese UTF-8 (Unicode 3.2) |
zh_HK.BIG5HK |
Traditional Chinese (Hong Kong) BIG5-HKSCS |
zh_HK.UTF-8 |
Traditional Chinese (Hong Kong) UTF-8 (Unicode 3.2) |
The following table lists supported code sets for each Traditional Chinese locale.
Table 1–2 Traditional Chinese Code Sets
Locale |
Code Set |
zh_TW.EUC (zh_TW) |
cns11643 |
zh_TW.BIG5 |
BIG5 |
zh_TW.UTF-8 |
UTF-8 |
zh_HK.BIG5HK |
BIG5-HKSCS |
zh_HK.UTF-8 |
Unicode 3.2 |
The Traditional Chinese Solaris Operating System provides input methods and fonts that enable you to enter, display, and print any character in any language. The following input methods are supported for the Traditional Chinese locales.
New ChuYin
ChuYin
TsangChieh
Array
Boshiamy
DaYi
JianYi
Cantonese
NeiMa (EUC, BIG5, BIG5-HKSCS)
English-Chinese
Optional codetable Input Methods, such as PinYin
For a complete list of fonts supported for the Traditional Chinese locales, see Chapter 9, Fonts.
The input method auxiliary window supports the following functions:
Input method switching
Input methods properties configuration
Lookup tables for the following character sets:
HKSCS
CNS11643
BIG5
Unicode
User-defined characters
Input method help
Virtual keyboard
You can use the following general and specific categories as defined by ANSI C for the Traditional Chinese and English locales.
General LC_ALL setting that invokes all of the categories for locale-related aspects of the system.
Specific settings for particular aspects of the system, which include:
LC_CTYPE
LC_TIME
LC_NUMERIC
LC_MONETARY
LC_COLLATE
LC_MESSAGES
For example, the Traditional Chinese and the English/ASCII locales have the LC_TIME category that defines the display of the time and date according to the cultural format, as well as the actual Traditional Chinese or English/ASCII characters used in the display.
