The Traditional Chinese Solaris operating system provides PostScript fonts in the Display PostScript System (DPS). This section describes the fonts and the DPS facilities. For further details, see Programming the Display PostScript System with X, published by Adobe Systems.
The Traditional Chinese Solaris operating system provides the DPS fonts listed in the following table.
Table 9–1 Traditional Chinese DPS Fonts|
Font Name |
Description |
Kai-Medium |
Alias of Kai-Medium-EUC-H |
Kai-Medium-EUC-H |
Kai-Medium font, EUC encoding, horizontal display; can be used like a Roman font |
Kai-Medium-EUC-V |
Kai-Medium font, EUC encoding, vertical display; can be used like a Roman font |
Kai-Medium-H |
Kai-Medium font, horizontal display, for making a composite with a Roman font |
Kai-Medium-V |
Kai-Medium font, vertical display; for making a composite with a Roman font |
Ming-Light |
Alias of Ming-Light-EUC-H |
Ming-Light-EUC-H |
Ming-Light font, EUC encoding, horizontal display; can be used like a Roman font |
Ming-Light-EUC-V |
Ming-Light font, EUC encoding, vertical display; can be used like a Roman font |
Ming-Light-H |
Ming-Light font, horizontal display, for making a composite with a Roman font |
Ming-Light-V |
Ming-Light font, vertical display; for making a composite with a Roman font |
The following figure shows a sample of Kai-Medium and Ming-Light fonts.
You can create composite fonts with a Roman font and one of the following Traditional Chinese fonts.
Ming-Light-H
Ming-Light-V
Kai-Medium-H
Kai-Medium-V
For example, the following PostScript code defines a sample composite font, Times-Italic+Kai-Medium. The Times-Italic font is used for the ASCII characters and the Kai-Medium horizontal font is used for the Traditional Chinese characters.
/Times-Italic+Kai-Medium 13 dict begin /FontName 1 index def /FMapType 4 def /Encoding [ 0 1 ] def /WMode 0 def /FontType 0 def /FontMatrix [1.0 0.0 0.0 1.0 0.0 0.0] def /FDepVector [ /Times-Italic findfont /Kai-Medium-H findfont ] def currentdict end definefont pop |
You can use Traditional Chinese fonts just as you use Roman fonts in DPS wrap definitions. The following code sample creates the display in the Hello World figure.
defineps PSWDisplayText(char *text) /pointSize 50 def /Helvetica pointSize selectfont (Hello World) stringwidth pop 2 div neg 0 moveto (Hello World) show /cpSize 40 def /Kai-Medium cpSize selectfont (text) stringwidth pop 2 div neg pointSize neg moveto (text) show endps |
You can include PSWDisplayText (Chinese text) in a C program to display the designated Chinese text.
The Traditional Chinese Solaris software provides TrueType support in DPS.
Before Solaris applications can use a modified BDF file, the file must be converted to a PCF format file.
Use a command line such as the one in the following exa,ple to convert the BDF file to PCF format.
system% bdftopcf -o myfont14.pcf myfont14.bdf |
The -o option enables the matrix encoding used for Asian PCF font files.
Replace the BDF file in the following directory with the converted PCF file: $OPENWINHOME/lib/locale/zh_TW/fonts
To add a new bitmap, move the .pcf font file into your font directory.
You can use a command such as the following to compress the .pcf font file before you move it:
system% compress myfont14.pcf |
Run the following commands in your font directory.
The .bdf file should not be in the font directory.
system% cat >> fonts.alias -new-myfont-medium-r-normal--16-140-75-75-c-140-cns11643-16 Myfont-Medium14 ^D system% mkfontdir system% xset +fp `pwd` |
You can use a command such as the following example to view your font.
system% xfd -fn Myfont-Medium14 |
