Boshiamy input mode works with the radicals that you use to compose Chinese characters. The radicals in this mode are easy to memorize by the shape, the sound, or the meaning. You can memorize the following rules to help you quickly enter Chinese characters:
Cut off long
Patch up short
Select the Boshiamy input mode.
Follow the steps in the procedure How to Select an Input Method to select the input mode.
Boshiamy appears in the status window.
Type the set of radicals uoo.
Press the spacebar to commit the corresponding Chinese character.
