Telecode conversion uses the old four-digit codes used by the Taiwan Telephone & Telegraph Bureau. The four-digit codes uniquely identify 16356 Chinese characters. The codes are organized into two planes: plane 1, numbered from 0000 to 8045 and plane 2, numbered from .0000 to.8489.
This section contains instructions on how to use the Telecode input mode to input Chinese characters
Select the input method.
Follow the steps in the procedure How to Select an Input Method to select the input method.
Telecode appears in the status area.
Type the first three digits of the code 3456.
Press the spacebar.
The Telecode input converter finds a single matching character.
