Select the input mode.
Follow the steps in the procedure How to Select an Input Method to select the input mode.
ChienI appears in the status area.
Type the key sequence ak.
The ChienI input converter finds several matching characters and displays a lookup choice window.
Press 1 to select the appropriate character.
The radical is converted and the correct character appears.
