How to Change the Sequence of Frequently Used Chinese Characters and
Phrases
The New ChuYin input method
automatically recalls the most recently selected list items. The items appear
at the top of a list of phrases and characters for easy selection.
Using the New ChuYin input method, type the key sequence gfu.
Note the sequence of the choices that appear.
Select the third item, C, from the list of lookup
choices.
Type the gfu key sequence again.
The selection you made for gfu in the previous step
now appears as the first choice in the list.
