This chapter provides instructions for dynamically configuring devices in the Solaris OS. You can add, remove, or replace devices in the Solaris OS while the system is still running, if the system components support hot-plugging. If the system components do not support hot-plugging, you can reboot the system to reconfigure the devices.
For information on the procedures associated with dynamically configuring devices, see the following:
For information on hot-plugging USB devices with the cfgadm command, see Hot-Plugging USB Devices With the cfgadm Command.
For information on hot-plugging InfiniBand devices with cfgadm command, see Chapter 9, Using InfiniBand Devices (Overview/Tasks).
For information about accessing devices, see Accessing Devices.
Hot-plugging is the ability to physically add, remove, or replace system components while the system is running. Dynamic reconfiguration refers to the ability to hot-plug system components. This term also refers to the general ability to move system resources (both hardware and software) around in the system or to disable them in some way without physically removing them from the system.
Generally, you can hot-plug the following bus types:
USB
Fibre Channel
1394
ATA
SCSI
Infiniband
In addition, you can hot-plug the following devices with the cfgadm command:
USB devices on SPARC and x86 platforms
SCSI devices on SPARC and x86 platforms
PCI devices on SPARC and x86 platforms
PCIe devices on SPARC or x86 platforms
InfiniBand devices on SPARC and x86 devices
Features of the cfgadm command include the following:
Displaying system component status
Testing system components
Changing component configurations
Displaying configuration help messages
The benefit of using the cfgadm command to reconfigure systems components is that you can add, remove, or replace components while the system is running. An added benefit is that the cfgadm command guides you through the steps needed to add, remove, or replace system components.
For step-by-step instructions on hot-plugging components, see the following:
Not all SCSI and PCI controllers support hot-plugging with the cfgadm command.
As part of Sun's high availability strategy, dynamic reconfiguration is expected to be used in conjunction with additional layered products, such as alternate pathing or fail over software. Both products provide fault tolerance in the event of a device failure.
Without any high availability software, you can replace a failed device by manually stopping the appropriate applications, unmounting noncritical file systems, and then proceeding with the add or remove operations.
Some systems have slots that hot-pluggable and slots that are not hot-pluggable. For information about hot-plugging devices on your specific hardware configuration, such as on enterprise-level systems, refer to your hardware configuration documentation.
The cfgadm command displays information about attachment points, which are locations in the system where dynamic reconfiguration operations can occur.
An attachment point consists of the following:
An occupant, which represents a hardware component that can be configured into the system
A receptacle, which is the location that accepts the occupant
Attachment points are represented by logical and physical attachment point IDs (Ap_Ids). The physical Ap_Id is the physical path name of the attachment point. The logical Ap_Id is a user-friendly alternative for the physical Ap_Id. For more information on Ap_Ids, refer to cfgadm(1M).
The logical Ap_Id for a SCSI Host Bus Adapter (HBA), or SCSI controller, is usually represented by the controller number, such as c0.
In cases where no controller number has been assigned to a SCSI HBA, then an internally generated unique identifier is provided. An example of a unique identifier for a SCSI controller is the following:
fas1:scsi
The logical Ap_Id for a SCSI device usually has this format:
HBA-logical-apid::device-identifier
In the following example, c0 is the logical Ap_Id for the SCSI HBA:
c0::dsk/c0t3d0
The device identifier is typically derived from the logical device name for the device in the /dev directory. For example, a tape device with logical device name, /dev/rmt/1, has the following logical Ap_Id:
c0::rmt/1
If a logical Ap_Id of a SCSI device cannot be derived from the logical name in the /dev directory, then an internally generated unique identifier is provided. An example of an identifier for the /dev/rmt/1 tape device is the following:
c0::st4
For more information on SCSI Ap_Ids, refer to cfgadm_scsi(1M).
The cfgadm command represents all resources and dynamic reconfiguration operations in terms of a common set of states (such as configured and unconfigured) and operations (such as connect, configure, unconfigure, and so on). For more information on these common states and operations, see cfgadm(1M).
The following table shows the receptacle and occupant states for the SCSI HBA attachment points.
Receptacle State |
Description |
Occupant State |
Description |
empty |
N/A for SCSI HBA |
configured |
One or more devices is configured on the bus |
disconnected |
Bus quiesced |
unconfigured |
No devices are configured |
connected |
Bus active |
The following table shows the receptacle and occupant states for SCSI device attachment points.
Receptacle State |
Description |
Occupant State |
Description |
empty |
N/A for SCSI devices |
configured |
Device is configured |
disconnected |
Bus quiesced |
unconfigured |
Device is not configured |
connected |
Bus active |
The state of SCSI attachment points is unknown unless special hardware indicates otherwise. For instructions on displaying SCSI component information, see How to Display Information About SCSI Devices.
A PCI adapter card that is hosting nonvital system resources can be removed if the device driver supports hot-plugging. A PCI adapter card is not detachable if it is a vital system resource. For a PCI adapter card to be detachable, the following conditions must be met:
The device driver must support hot-plugging.
Critical resources must be accessible through an alternate pathway.
For example, if a system has only one Ethernet card installed in it, the Ethernet card cannot be detached without losing the network connection. This detachment requires additional layered software support to keep the network connection active.
A PCI adapter card can be added to the system as long as the following conditions are met:
There are slots available.
The device driver supports hot-plugging for this adapter card.
For step-by-step instructions on adding or removing a PCI adapter card, see PCI or PCIe Hot-Plugging With the cfgadm Command.
You can use the hotplug command to manage hot pluggible connections, where a connection can be a connector or port, on PCI Express (PCIe) and PCI SHPC devices only. A hotplug connector is a physical representation in the system where a component is inserted or removed. A hotplug port is a logical representation in the system device tree where the connection of a device to the system is managed.
You can use the hotplug features to online or offline a device, even an on-board device, without physically adding or removing the device from the system.
You must enable the hotplug service to manage devices with the hotplug command.
# svcadm enable svc:/system/hotplug:default |
The following examples describe how to use the hotplug command.
Display all the PCI/PCIe hot pluggible connectors/ports (virtual and physical) in the system as follows:
# hotplug list -lv |
Configure an Ethernet card in a PCIe slot. For example:
# hotplug enable /pci0,0 pcie0 |
Unconfigure an Ethernet card in a PCIe slot. For example:
# hotplug disable /pci0,0 pcie0 |
Offline a PCI device node, which means detach the device driver for that node. For example:
# hotplug offline /pci0,0/pci1 pci.0,2 |
Online a PCI device node, which means attach the driver for that node. For example:
# hotplug online /pci0,0/pci1 pci.0,2 |
The following service must be running to use the hotplug command.
Otherwise, you will see the following message:
ERROR: hotplug service is not available. |
The following error message is displayed on systems that do not have any supported I/O buses:
ERROR: there are no connections to display.
(See hotplug(1m) for more information.)
The above message could mean that the system might have other hot-pluggible I/O devices, but you need to use the cfgadm command rather than the hotplug command to manage these devices.
Task |
Description |
For Instructions |
Display information about SCSI devices. |
Display information about SCSI controllers and devices. | |
Unconfigure a SCSI controller. |
Unconfigure a SCSI controller. | |
Configure a SCSI controller. |
Configure a SCSI controller that was previously unconfigured. | |
Configure a SCSI device. |
Configure a specific SCSI device. | |
Disconnect a SCSI controller. |
Disconnect a specific SCSI controller. | |
Connect a SCSI controller. |
Connect a specific SCSI controller that was previously disconnected. | |
Add a SCSI device to a SCSI bus. |
Add a specific SCSI device to a SCSI bus. | |
Replace an identical device on a SCSI controller. |
Replace a device on the SCSI bus with another device of the same type. |
SPARC: How to Replace an Identical Device on a SCSI Controller |
Remove a SCSI device. |
Remove a SCSI device from the system. | |
Troubleshoot SCSI configuration problems. |
Resolve a failed SCSI unconfigure operation. |
This section describes various SCSI hot-plugging procedures that you can perform with the cfgadm command.
The SCSI framework generally supports hot-plugging of SCSI devices. However, you should consult your hardware documentation to confirm whether hot-plugging is supported for your SCSI devices.
These procedures use specific devices as examples to illustrate how to use the cfgadm command to hot-plug SCSI components. The device information that you supply, and that the cfgadm command displays, depends on your system configuration.
The following procedure uses SCSI controllers c0 and c1 and the devices that are attached to them in the examples of the type of device configuration information that you can display with the cfgadm command.
If the SCSI device is not supported by the cfgadm command, the device does not display in the cfgadm command output.
Become superuser.
Display information about attachment points on the system.
# cfgadm -l Ap_Id Type Receptacle Occupant Condition c0 scsi-bus connected configured unknown c1 scsi-bus connected configured unknown |
In this example, c0 and c1 represent two SCSI controllers.
Display information about a system's SCSI controllers and their attached devices.
# cfgadm -al Ap_Id Type Receptacle Occupant Condition c0 scsi-bus connected configured unknown c0::dsk/c0t0d0 disk connected configured unknown c0::rmt/0 tape connected configured unknown c1 scsi-bus connected configured unknown c1::dsk/c1t3d0 disk connected configured unknown c1::dsk/c1t4d0 unavailable connected unconfigured unknown |
The cfgadm -l commands displays information about SCSI HBAs but not SCSI devices. Use the cfgadm -al command to display information about SCSI devices such as disk and tapes.
The following procedure uses SCSI controller c1 in the example of unconfiguring a SCSI controller.
Become superuser.
# cfgadm -c unconfigure c1 |
Verify that the SCSI controller is unconfigured.
# cfgadm -al Ap_Id Type Receptacle Occupant Condition c0 scsi-bus connected configured unknown c0::dsk/c0t0d0 disk connected configured unknown c0::rmt/0 tape connected configured unknown c1 scsi-bus connected unconfigured unknown |
Notice that the Occupant column for c1 specifies unconfigured, indicating that the SCSI bus has no configured occupants.
If the unconfigure operation fails, see How to Resolve a Failed SCSI Unconfigure Operation.
The following procedure uses SCSI controller c1 in the example of configuring a SCSI controller.
Become superuser.
# cfgadm -c configure c1 |
Verify that the SCSI controller is configured.
The previous unconfigure procedure removed all devices on the SCSI bus. Now all the devices are configured back into the system.
The following procedure uses SCSI disk c1t4d0 in the example of configuring a SCSI device.
Become superuser.
Identify the device to be configured.
Configure the SCSI device.
# cfgadm -c configure c1::dsk/c1t4d0 |
Verify that the SCSI device is configured.
# cfgadm -al Ap_Id Type Receptacle Occupant Condition c0 scsi-bus connected configured unknown c0::dsk/c0t0d0 disk connected configured unknown c0::rmt/0 tape connected configured unknown c1 scsi-bus connected configured unknown c1::dsk/c1t3d0 disk connected configured unknown c1::dsk/c1t4d0 disk connected configured unknown |
Disconnecting a SCSI device must be done with caution, particularly when you are dealing with controllers for disks that contain critical file systems such as root (/), usr, var, and the swap partition. The dynamic reconfiguration software cannot detect all cases where a system hang might result. Use this procedure with caution.
The following procedure uses SCSI controller c1 in the example of disconnecting a SCSI device.
Become superuser.
Verify that the device is connected before you disconnect it.
Disconnect the SCSI controller.
# cfgadm -c disconnect c1 WARNING: Disconnecting critical partitions may cause system hang. Continue (yes/no)? y |
This command suspends all I/O activity on the SCSI bus until the cfgadm -c connect command is used. The cfgadm command does some basic checking to prevent critical partitions from being disconnected, but it cannot detect all cases. Inappropriate use of this command can result in a system hang and could require a system reboot.
Verify that the SCSI bus is disconnected.
# cfgadm -al Ap_Id Type Receptacle Occupant Condition c0 scsi-bus connected configured unknown c0::dsk/c0t0d0 disk connected configured unknown c0::rmt/0 tape connected configured unknown c1 unavailable disconnected configured unknown c1::dsk/c1t3d0 unavailable disconnected configured unknown c1::dsk/c1t4d0 unavailable disconnected configured unknown |
The controller and all the devices that are attached to it are disconnected from the system.
The following procedure uses SCSI controller c1 in the example of connecting a SCSI controller.
Become superuser.
Verify that the device is disconnected before you connect it.
Connect the SCSI controller.
# cfgadm -c connect c1 |
Verify that the SCSI controller is connected.
SCSI controller c1 is used in the example of how to add a SCSI device to a SCSI bus.
When you add devices, you specify the Ap_Id of the SCSI HBA (controller) to which the device is attached, not the Ap_Id of the device itself.
Become superuser.
Identify the current SCSI configuration.
# cfgadm -al Ap_Id Type Receptacle Occupant Condition c0 scsi-bus connected configured unknown c0::dsk/c0t0d0 disk connected configured unknown c0::rmt/0 tape connected configured unknown c1 scsi-bus connected configured unknown c1::dsk/c1t3d0 disk connected configured unknown |
Add the SCSI device to the SCSI bus.
Type the following cfgadm command.
For example:
# cfgadm -x insert_device c1 Adding device to SCSI HBA: /devices/sbus@1f,0/SUNW,fas@1,8800000 This operation will suspend activity on SCSI bus: c1 |
Type y at the Continue (yes/no)? prompt to proceed.
Continue (yes/no)? y SCSI bus quiesced successfully. It is now safe to proceed with hotplug operation. |
I/O activity on the SCSI bus is suspended while the hot-plug operation is in progress.
Connect the device and then power it on.
Type y at the Enter y if operation is complete or n to abort (yes/no)? prompt.
Enter y if operation is complete or n to abort (yes/no)? y |
Verify that the device has been added.
A new disk has been added to controller c1.
The following procedure uses SCSI disk c1t4d0 in the example of replacing an identical device on a SCSI controller.
Become superuser.
For example:
# cfgadm -x replace_device c1::dsk/c1t4d0 Replacing SCSI device: /devices/sbus@1f,0/SUNW,fas@1,8800000/sd@4,0 This operation will suspend activity on SCSI bus: c1 |
Power off the device to be removed and remove it.
Add the replacement device. Then, power it on.
The replacement device should be of the same type and at the same address (target and lun) as the device to be removed.
Verify that the device has been replaced.
The following procedure uses SCSI disk c1t4d0 in the example of removing a device on a SCSI controller.
Become superuser.
Remove the SCSI device from the system.
For example:
# cfgadm -x remove_device c1::dsk/c1t4d0 Removing SCSI device: /devices/sbus@1f,0/SUNW,fas@1,8800000/sd@4,0 This operation will suspend activity on SCSI bus: c1 |
This step must be performed if you are removing a SCSI RAID device from a SCSI RAID array.
Verify that the device has been removed from the system.
This section provides error messages and possible solutions for troubleshooting SCSI configuration problems. For more information on troubleshooting SCSI configuration problems, see cfgadm(1M).
cfgadm: Component system is busy, try again: failed to offline:
device-path
Resource Information
/dev/dsk/c1t0d0s0 mounted filesystem "/file-system"
You attempted to remove or replace a device with a mounted file system.
Unmount the file system that is listed in the error message and retry the cfgadm operation.
device-path
/dev/dsk/device-name swap area
If you use the cfgadm command to remove a system resource, such as a swap device or a dedicated dump device, a similar error message is displayed if the system resource is still active.
Unconfigure the swap areas on the device that is specified and retry the cfgadm operation.
device-path
/dev/dsk/device-name dump device (swap)
You attempted to remove or replace a dump device that is configured on a swap area.
Unconfigure the dump device that is configured on the swap area and retry the cfgadm operation.
device-path
/dev/dsk/device-name dump device (dedicated)
You attempted to remove or replace a dedicated dump device.
Unconfigure the dedicate dump device and retry the cfgadm operation.
Use this procedure if one or more target devices are busy and the SCSI unconfigure operation fails. Otherwise, future dynamic reconfiguration operations on this controller and target devices will fail with a dr in progress message.
The following task map describes the tasks for managing PCI or PCIe devices on your system.
Task |
Description |
For Instructions |
Display PCI slot configuration information. |
Display the status of PCI hot-pluggable devices and slots on the system. | |
Remove a PCI adapter card. |
Unconfigure the card, disconnect power from the slot, and remove the card from the system. | |
Add a PCI adapter card. |
Insert the adapter card into a hot-pluggable slot, connect power to the slot, and configure the card. | |
Troubleshoot PCI configuration problems. |
Identify error message and possible solutions to resolve PCI configuration problems. |
This section provides step-by-step instructions for hot-plugging PCI or PCIe adapter cards on SPARC and x86 systems.
In addition to the cfgadm command, the prtconf command is helpful during hot-plug operations. The prtconf command displays additional configuration information that pertains to the hardware.
After adding hardware, you can use the prtconf command to verify that the hardware is configured correctly. For example, after a configure operation, use the prtconf -D command to verify that the driver is attached to the newly installed hardware device. If the device driver has not been added to the system prior to hardware configuration, it may be manually added by using the add_drv command.
For more information, see prtconf(1M) and add_drv(1M).
In the examples, only PCI attachment points are listed, for brevity. The attachment points that are displayed on your system depend on your system configuration.
You might observe the LED indicators on the system to get a visual indication about the status of the slot's hot-plug operation. The LED behavior, in case of PCI Express, matches that defined in the PCI Express specification or the behavior might otherwise be platform dependent.
Please refer to your platform guide for specific details. In case of PCI Express, when the Attention Button is pressed, the power indicator blinks, which indicates the beginning of a state transition. The blinking ends when the state transition has ended.
This procedure has been updated to include PCIe configuration information.
The cfgadm command displays the status of PCI hot-pluggable devices and slots on a system. For more information, see cfgadm(1M).
Become superuser.
Display PCI configuration information.
For example:
# cfgadm Ap_Id Type Receptacle Occupant Condition pci1:hpc0_slot0 unknown empty unconfigured unknown pci1:hpc0_slot1 unknown empty unconfigured unknown pci1:hpc0_slot2 unknown empty unconfigured unknown pci1:hpc0_slot3 ethernet/hp connected configured ok pci1:hpc0_slot4 unknown empty unconfigured unknown |
Display specific PCI device information.
For example:
# cfgadm -s "cols=ap_id:type:info" pci Ap_Id Type Information pci1:hpc0_slot0 unknown Slot 7 pci1:hpc0_slot1 unknown Slot 8 pci1:hpc0_slot2 unknown Slot 9 pci1:hpc0_slot3 ethernet/hp Slot 10 pci1:hpc0_slot4 unknown Slot 11 |
The logical Ap_Id, pci1:hpc0_slot0, is the logical Ap_Id for hot-pluggable slot, Slot 7. The component hpc0 indicates the hot-pluggable adapter card for this slot, and pci1 indicates the PCI bus instance. The Type field indicates the type of PCI adapter card that is present in the slot.
Display PCIe slot configuration information.
For example:
# cfgadm pci Ap_Id Type Receptacle Occupant Condition pcie1 unknown empty unconfigured unknown pcie2 unknown empty unconfigured unknown pcie3 unknown empty unconfigured unknown pcie4 etherne/hp connected configured ok pcie5 pci-pci/hp connected configured ok pcie6 unknown disconnected unconfigured unknown |
Display specific PCIe device information.
For example:
# cfgadm -s "cols=ap_id:busy:o_state" pci Ap_Id Busy Occupant pcie1 n unconfigured pcie2 n unconfigured pcie3 n unconfigured pcie4 n configured pcie5 n configured pcie6 n configured |
The logical Ap_Id in most cases should match the slot label that is silk-screened on the system chassis. Refer to your platform guide for the cfgadm output of the hot-pluggable slots. The Busy field can be displayed to ensure that the Ap_Id is not transitioning to another state before a hot-plug operation is attempted.
The following procedure has been updated for removing a PCIe adapter card. However, the procedure to remove an adapter card is the same whether you are using PCI or PCIe.
Become superuser.
Determine which slot the PCI adapter card is in.
For example:
Stop the application that has the device open.
For example, if the device is an Ethernet card, use the ifconfig command to bring down the interface and unplumb the interface.
Unconfigure the device manually by using the cfgadm(1M) command as shown below. Or, if you have a PCIe adapter card, use the auto-configuration method, such as pressing the slot's Attention Button as defined by your platform guide.
# cfgadm -c unconfigure pcie4 |
Confirm that the device has been unconfigured.
For example:
# cfgadm pci Ap_Id Type Receptacle Occupant Condition pcie1 unknown empty unconfigured unknown pcie2 unknown empty unconfigured unknown pcie3 unknown empty unconfigured unknown pcie4 unknown connected unconfigured unknown pcie5 pci-pci/hp connected configured ok pcie6 unknown disconnected unconfigured unknown |
The Type and Condition also become unknown when the device is unconfigured.
Disconnect the power to the slot manually. If the auto-configuration method is used, this step is not necessary. Refer to your platform guide for more information.
# cfgadm -c disconnect pcie4 |
Confirm that the device has been disconnected.
For example:
# cfgadm pci Ap_Id Type Receptacle Occupant Condition pcie1 unknown empty unconfigured unknown pcie2 unknown empty unconfigured unknown pcie3 unknown empty unconfigured unknown pcie4 unknown disconnected unconfigured unknown pcie5 pci-pci/hp connected configured ok pcie6 unknown disconnected unconfigured unknown |
Follow appropriate instructions in your platform guide to remove the PCI adapter card. After the card is removed, the Receptacle state is empty.
For example:
# cfgadm pci Ap_Id Type Receptacle Occupant Condition pcie1 unknown empty unconfigured unknown pcie2 unknown empty unconfigured unknown pcie3 unknown empty unconfigured unknown pcie4 unknown empty unconfigured unknown pcie5 pci-pci/hp connected configured ok pcie6 unknown disconnected unconfigured unknown |
The auto-configuration method can be enabled or disabled at boot, depending on the platform implementation. Set the auto-configuration method as appropriate for your environment.
The following procedure has been updated for adding a PCIe adapter card. However, the procedure to add an adapter card is the same whether you are using PCI or PCIe.
Become superuser.
Identify the hot-pluggable slot and open latches.
For example, pcie3.
Follow the appropriate instructions in your platform guide to insert a PCI adapter card into the slot.
Determine which slot the PCI adapter card is in after it is inserted.
For example:
# cfgadm pci Ap_Id Type Receptacle Occupant Condition pcie1 unknown empty unconfigured unknown pcie2 unknown empty unconfigured unknown pcie3 unknown disconnected unconfigured unknown pcie4 unknown empty unconfigured unknown pcie5 pci-pci/hp connected configured ok pcie6 unknown disconnected unconfigured unknown |
Connect the power to the slot manually using the cfgadm command. Or, if you have a PCIe adapter card, use the auto-configuration method, such as pressing the slot's Attention Button as defined by your platform guide.
For example:
# cfgadm -c connect pcie3 |
Confirm that the attachment point is connected.
For example:
# cfgadm pci Ap_Id Type Receptacle Occupant Condition pcie1 unknown empty unconfigured unknown pcie2 unknown empty unconfigured unknown pcie3 unknown connected unconfigured unknown pcie4 unknown empty unconfigured unknown pcie5 pci-pci/hp connected configured ok pcie6 unknown disconnected unconfigured unknown |
Configure the PCI adapter card manually by using the cfgadm command as shown below. If using the auto-configuration method, this step should not be necessary. Refer to your platform guide for more information.
For example:
# cfgadm -c configure pcie3 |
Verify the configuration of the PCI adapter card in the slot.
For example:
# cfgadm pci Ap_Id Type Receptacle Occupant Condition pcie1 unknown empty unconfigured unknown pcie2 unknown empty unconfigured unknown pcie3 etherne/hp connected configured unknown pcie5 pci-pci/hp connected configured ok pcie6 unknown disconnected unconfigured unknown |
Configure any supporting software if this device is a new device.
For example, if this device is an Ethernet card, use the ifconfig command to set up the interface.
cfgadm: Configuration operation invalid: invalid transition |
An invalid transition was attempted.
Check whether the cfgadm -c command was issued appropriately. Use the cfgadm command to check the current receptacle and occupant state and to make sure that the Ap_Id is correct.
cfgadm: Attachment point not found |
The specified attachment point was not found.
Check whether the attachment point is correct. Use the cfgadm command to display a list of available attachment points. Also check the physical path to see if the attachment point is still there.
The Reconfiguration Coordination Manager (RCM) is the framework that manages the dynamic removal of system components. By using RCM, you can register and release system resources in an orderly manner.
You can use the new RCM script feature to write your own scripts to shut down your applications, or to cleanly release the devices from your applications during dynamic reconfiguration. The RCM framework launches a script automatically in response to a reconfiguration request, if the request impacts the resources that are registered by the script.
You can also release resources from applications manually before you dynamically remove the resource. Or, you can use the cfgadm command with the -f option to force a reconfiguration operation. However, this option might leave your applications in an unknown state. Also, the manual release of resources from applications commonly causes errors.
The RCM script feature simplifies and better controls the dynamic reconfiguration process. By creating an RCM script, you can do the following:
Automatically release a device when you dynamically remove a device. This process also closes the device if the device is opened by an application.
Run site-specific tasks when you dynamically remove a device from the system.
An executable shell script (Perl, sh, csh, or ksh) or binary program that the RCM daemon runs. Perl is the recommended language.
A script that runs in its own address space by using the user ID of the script file owner.
A script that is run by the RCM daemon when you use the cfgadm command to dynamically reconfigure a system resource.
You can use an RCM script to release a device from an application when you dynamically remove a device. If the device is currently open, the RCM script also closes the device.
For example, an RCM script for a tape backup application can inform the tape backup application to close the tape drive or shut down the tape backup application.
You can invoke an RCM script as follows:
$ script-name command [args ...] |
An RCM script performs the following basic steps:
Takes the RCM command from command-line arguments.
Executes the command.
Writes the results to stdout as name-value pairs.
Exits with the appropriate exit status.
The RCM daemon runs one instance of a script at a time. For example, if a script is running, the RCM daemon does not run the same script until the first script exits.
You must include the following RCM commands in an RCM script:
scriptinfo – Gathers script information
register – Registers interest in resources
resourceinfo – Gathers resource information
You might include some or all of the following RCM commands:
queryremove – Queries whether the resource can be released
preremove – Releases the resource
postremove – Provides post-resource removal notification
undoremove – Undoes the actions done in preremove
For a complete description of these RCM commands, see rcmscript(4).
When you dynamically remove a device, the RCM daemon runs the following:
The script's register command to gather the list of resources (device names) that are identified in the script.
The script's queryremove and preremove commands prior to removing the resource if the script's registered resources are affected by the dynamic remove operation.
The script's postremove command if the remove operation succeeds. However, if the remove operation fails, the RCM daemon runs the script's undoremove command.
The following sections describe the RCM script tasks for application developers and system administrators.
The following task map describes the tasks for an application developer who is creating an RCM script.
Task |
Description |
For Instructions |
1. Identify the resources your application uses. |
Identify the resources (device names) your application uses that you could potentially dynamically remove. | |
2. Identify the commands to release the resource. |
Identify the commands for notifying the application to cleanly release the resource from the application. |
Application documentation |
3. Identify the commands for post-removal of the resource. |
Include the commands for notifying the application of the resource removal. | |
4. Identify the commands if the resource removal fails. |
Include the commands for notifying the application of the available resource. | |
5. Write the RCM script. |
Write the RCM script based on the information identified in tasks 1-4. | |
6. Install the RCM script. |
Add the script to the appropriate script directory. | |
7. Test the RCM script |
Test the script by running the script commands manually and by initiating a dynamic reconfiguration operation. |
The following task map describes the tasks for a system administrator who is creating an RCM script to do site customization.
Task |
Description |
For Instructions |
1. Identify the resources to be dynamically removed. |
Identify the resources (device names) to be potentially removed by using the cfgadm -l command. | |
2. Identify the applications to be stopped. |
Identify the commands for stopping the applications cleanly. |
3. Identify the commands for pre-removal and post-removal of the resource. |
Identify the actions to be taken before and after the resource is removed. | |
4. Write the RCM script. |
Write the RCM script based on the information identified in tasks 1-3. | |
5. Install the RCM script. |
6. Test the RCM script. |
A script must be named as vendor,service where the following applies:
Is the stock symbol of the vendor that provides the script, or any distinct name that identifies the vendor.
Is the name of the service that the script represents.
You must be superuser (root) to install or remove an RCM script. Use this table to determine where you should install your RCM script.
Table 6–1 RCM Script Directories|
Directory Location |
Script Type |
/etc/rcm/scripts |
Scripts for specific systems |
/usr/platform/`uname -i`/lib/rcm/scripts |
Scripts for a specific hardware implementation |
/usr/platform/`uname -m`/lib/rcm/scripts |
Scripts for a specific hardware class |
/usr/lib/rcm/scripts |
Scripts for any hardware |
Become superuser.
Copy the script to the appropriate directory.
See Table 6–1.
For example:
# cp SUNW,sample.pl /usr/lib/rcm/scripts |
Change the user ID and the group ID of the script to the desired values.
# chown user:group /usr/lib/rcm/scripts/SUNW,sample.pl |
Send SIGHUP to the RCM daemon.
# pkill -HUP -x -u root rcm_daemon |
Become superuser.
Remove the script from the RCM script directory.
For example:
# rm /usr/lib/rcm/scripts/SUNW,sample.pl |
Set environment variables, such as RCM_ENV_FORCE, in the command-line shell before running your script.
For example, in the Korn shell, use the following:
$ export RCM_ENV_FORCE=TRUE |
Test the script by running the script commands manually from the command line.
For example:
$ script-name scriptinfo $ script-name register $ script-name preremove resource-name $ script-name postremove resource-name |
Make sure that each RCM script command in your script prints appropriate output to stdout.
Install the script in the appropriate script directory.
For more information, see How to Install an RCM Script.
Test the script by initiating a dynamic remove operation.
For example, assume your script registers the device, /dev/dsk/c1t0d0s0. Try these commands.
$ cfgadm -c unconfigure c1::dsk/c1t0d0 $ cfgadm -f -c unconfigure c1::dsk/c1t0d0 $ cfgadm -c configure c1::dsk/c1t0d0 |
Make sure that you are familiar with these commands because they can alter the state of the system and cause system failures.
This example illustrates how to use an RCM script for tape backups.
The tape backup RCM script performs the following steps:
Sets up a dispatch table of RCM commands.
Calls the dispatch routine that corresponds to the specified RCM command and exits with status 2 for unimplemented RCM commands.
Sets up the scriptinfo section.
rcm_script_func_info=Tape backup appl script for DR |
Registers all tape drives in the system by printing all tape drive device names to stdout.
rcm_resource_name=/dev/rmt/$f |
If an error occurs, the script prints the error information to stdout.
rcm_failure_reason=$errmsg |
Sets up the resource information for the tape device.
rcm_resource_usage_info=Backup Tape Unit Number $unit |
Sets up the preremove information by checking if the backup application is using the device. If the backup application is not using the device, the dynamic reconfiguration operation continues. If the backup application is using the device, the script checks RCM_ENV_FORCE. If RCM_ENV_FORCE is set to FALSE, the script denies the dynamic reconfiguration operation and prints the following message:
rcm_failure_reason=tape backup in progress pid=... |
If RCM_ENV_FORCE is set to TRUE, the backup application is stopped, and the reconfiguration operation proceeds.
Here are the various outcomes if you use the cfgadm command to remove a tape device without the RCM script.
If you use the cfgadm command and the backup application is not using the tape device, the operation succeeds.
If you use the cfgadm command and the backup application is using the tape device, the operation fails.
Here are the various outcomes if you use the cfgadm command to remove a tape device with the RCM script.
If you use the cfgadm command without the -f option and the backup application is using the tape device, the operation fails with an error message similar to the following:
If you use the cfgadm -f command and the backup application is using the tape device, the script stops the backup application and the cfgadm operation succeeds.
#! /usr/bin/perl -w
# A sample site customization RCM script.
# When RCM_ENV_FORCE is FALSE this script indicates to RCM that it cannot
# release the tape drive when the tape drive is being used for backup.
# When RCM_ENV_FORCE is TRUE this script allows DR removing a tape drive
# when the tape drive is being used for backup by killing the tape
# backup application.
use strict;
my ($cmd, %dispatch);
$cmd = shift(@ARGV);
# dispatch table for RCM commands
%dispatch = (
"scriptinfo" => \&do_scriptinfo,
"register" => \&do_register,
"resourceinfo" => \&do_resourceinfo,
"queryremove" => \&do_preremove,
"preremove" => \&do_preremove
if (defined($dispatch{$cmd})) {
&{$dispatch{$cmd}};
} else {
exit (2);
sub do_scriptinfo
print "rcm_script_version=1\n";
print "rcm_script_func_info=Tape backup appl script for DR\n";
exit (0);
sub do_register
my ($dir, $f, $errmsg);
$dir = opendir(RMT, "/dev/rmt");
if (!$dir) {
$errmsg = "Unable to open /dev/rmt directory: $!";
print "rcm_failure_reason=$errmsg\n";
exit (1);
while ($f = readdir(RMT)) {
# ignore hidden files and multiple names for the same device
if (($f !~ /^\./) && ($f =~ /^[0-9]+$/)) {
print "rcm_resource_name=/dev/rmt/$f\n";
closedir(RMT);
exit (0);
sub do_resourceinfo
my ($rsrc, $unit);
$rsrc = shift(@ARGV);
if ($rsrc =~ /^\/dev\/rmt\/([0-9]+)$/) {
$unit = $1;
print "rcm_resource_usage_info=Backup Tape Unit Number $unit\n";
exit (0);
} else {
print "rcm_failure_reason=Unknown tape device!\n";
exit (1);
sub do_preremove
my ($rsrc);
# check if backup application is using this resource
#if (the backup application is not running on $rsrc) {
# allow the DR to continue
# exit (0);
# If RCM_ENV_FORCE is FALSE deny the operation.
# If RCM_ENV_FORCE is TRUE kill the backup application in order
# to allow the DR operation to proceed
if ($ENV{RCM_ENV_FORCE} eq 'TRUE') {
if ($cmd eq 'preremove') {
# kill the tape backup application
exit (0);
} else {
# indicate that the tape drive can not be released
# since the device is being used for backup by the
# tape backup application
print "rcm_failure_reason=tape backup in progress pid=...\n"
exit (3);
