The format utility is most often used by system administrators to partitioning a Disk. The steps are as follows:
Determining which slices are needed
Determining the size of each slice or partition
Using the format utility to partition the disk
Labeling the disk with new partition information
Creating the file system for each partition
The easiest way to partition a disk is to use the modify command from the partition menu of the format utility. The modify command allows you to create partitions by specifying the size of each partition without having to keep track of the starting cylinder boundaries. The modify command also keeps tracks of any disk space that remains in the “free hog” slice.
An important part of the disk label is the partition table. The partition table identifies a disk's slices, the slice boundaries (in cylinders), and the total size of the slices. You can display a disk's partition table by using the format utility. The following describes partition table terminology.
Table 10–6 Partition Table Terminology
Partition Term |
Value |
Description |
Number |
0–7 |
VTOC – Partitions or slices, numbered 0–7. EFI – Partitions or slices, numbered 0–6. |
Tag |
0=UNASSIGNED 1=BOOT 2=ROOT 3=SWAP 4=USR 5=BACKUP 7=VAR 8=HOME 11=RESERVED |
A numeric value that usually describes the file system mounted on this partition. |
Flags |
wm |
The partition is writable and mountable. |
wu rm |
The partition is writable and unmountable. This state is the default for partitions that are dedicated for swap areas. (However, the mount command does not check the “not mountable” flag.) |
rm |
The partition is read only and mountable. |
Partition flags and tags are assigned by convention and require no maintenance.
For more information on displaying the partition table, see the following references:
The following format utility output shows an example of a partition table from a 74-GB disk with a VTOC label displayed:
Total disk cylinders available: 38756 + 2 (reserved cylinders) Part Tag Flag Cylinders Size Blocks 0 root wm 3 - 2083 4.00GB (2081/0/0) 8390592 1 swap wu 2084 - 3124 2.00GB (1041/0/0) 4197312 2 backup wm 0 - 38755 74.51GB (38756/0/0) 156264192 3 unassigned wm 0 0 (0/0/0) 0 4 unassigned wm 0 0 (0/0/0) 0 5 unassigned wm 0 0 (0/0/0) 0 6 unassigned wm 0 0 (0/0/0) 0 7 home wm 3125 - 38755 68.50GB (35631/0/0) 143664192 8 boot wu 0 - 0 1.97MB (1/0/0) 4032 9 alternates wu 1 - 2 3.94MB (2/0/0) 8064 partition> |
The partition table displayed by the format utility contains the following information.
Column Name |
Description |
Part |
Partition or slice number. See Table 10–6 for a description of this column. |
Tag |
Partition tag. See Table 10–6 for a description of this column. |
Flag |
Partition flag. See Table 10–6 for a description of this column. |
Cylinders |
The starting and ending cylinder number for the slice. Not displayed on EFI-labeled disks. |
Size |
The slice size in MB. |
Blocks |
The total number of cylinders and the total number of sectors per slice. Not displayed on EFI-labeled disks. |
First Sector |
EFI – The starting block number. Not displayed on VTOC-labeled disks. |
Last Sector |
EFI – The ending block number. Not displayed on VTOC-labeled disks. |
The following is an example of an EFI disk label displayed by using the prtvtoc command.
# prtvtoc /dev/rdsk/c4t1d0s0 * /dev/rdsk/c4t1d0s0 partition map * * Dimensions: * 512 bytes/sector * 2576941056 sectors * 2576940989 accessible sectors * * Flags: * 1: unmountable * 10: read-only * * First Sector Last * Partition Tag Flags Sector Count Sector Mount Directory 0 2 00 34 629145600 629145633 1 4 00 629145634 629145600 1258291233 6 4 00 1258291234 1318633404 2576924637 8 11 00 2576924638 16384 2576941021 |
The output of the prtvtoc command provides information in the following three sections:
Dimensions
Flags
Partition Table
prtvtoc Column Name |
Description |
Partition |
Partition or slice number. For a description of this column, see Table 10–6. |
Tag |
Partition tag. For a description of this column, see Table 10–6. |
Flags |
Partition flag. For a description of this column, see Table 10–6. |
First Sector |
The first sector of the slice. |
Sector Count |
The total number of sectors in the slice. |
Last Sector |
The last sector of the slice. |
Mount Directory |
The last mount point directory for the file system. |
When you use the format utility to change the size of one or more disk slices, you designate a temporary slice that will expand and shrink to accommodate the resizing operations.
This temporary slice donates, or “frees,” space when you expand a slice, and receives, or “hogs,” the discarded space when you shrink a slice. For this reason, the donor slice is sometimes called the free hog.
The free hog slice exists only during installation or when you run the format utility. There is no permanent free hog slice during day-to-day operations.
For information on using the free hog slice, see SPARC: How to Create Disk Slices and Label a Disk or x86: How to Create Disk Slices and Label a Disk.
