read
Reads each sector on the current disk. Repairs defective blocks as a
default.
refresh
Reads then writes data on the current disk without harming the data.
Repairs defective blocks as a default.
test
Writes a set of patterns to the disk without harming the data. Repairs
write
Writes a set of patterns to the disk then reads back the data on the
disk. Destroys existing data on the disk. Repairs defective blocks as a default.
compare
Writes a set of patterns to the disk, reads back the data, and then
compares it to the data in the write buffer. Destroys existing data on the
purge
Removes all data from the disk so that the data cannot be retrieved
by any means. Data is removed by writing three distinct patterns over the
entire disk (or a section of the disk). If the verification passes, a hex-bit
pattern is written over the entire disk (or a section of the disk).
verify
In the first pass, writes unique data to each block on the entire disk.
In the next pass, reads and verifies the data. Destroys existing data on
print
Displays the data in the read/write buffer.
setup
Enables you to specify the following analysis parameters:
Analyze entire disk? yes
Starting block number: depends on drive
Ending block number: depends on drive
Loop continuously? no
Number of passes: 2
Repair defective blocks? yes
Stop after first error? no
Use random bit patterns? no
Number of blocks per transfer: 126 (0/n/nn)
Verify media after formatting? yes
Enable extended messages? no
Restore defect list? yes
Restore disk label? yes
config
Displays the current analysis parameters.
quit
Exits the analyze menu.
