The fdisk menu appears on x86 based systems only and appears similar to the following.
format> fdisk
Total disk size is 14169 cylinders
Cylinder size is 2510 (512 byte) blocks
Cylinders
Partition Status Type Start End Length %
1 Active x86 Boot 1 9 9 0
2 Solaris2 10 14168 14159 100
SELECT ONE OF THE FOLLOWING:
1. Create a partition
2. Specify the active partition
3. Delete a partition
4. Change between Solaris and Solaris2 Partition IDs
5. Exit (update disk configuration and exit)
6. Cancel (exit without updating disk configuration)
Enter Selection:
The following table describes the fdisk menu items.
Table 15–3 x86: Descriptions for fdisk Menu Items|
Menu Item |
Description |
Create a partition |
Creates an fdisk partition. You must create a separate partition for each OS such as Solaris or DOS. There is a maximum of four partitions per disk. You are prompted for the size of the fdisk partition as a percentage of the disk. |
Specify the active partition |
Enables you to specify the partition to be used for booting. This menu item identifies where the first stage boot program looks for the second stage boot program. |
Delete a partition |
Deletes a previously created partition. This command destroys all the data in the partition. |
Change between Solaris and Solaris2 Partition IDs |
Changes partition IDs from 130 (0x82) to 191 (0xbf) and back again. |
Exit (update disk configuration and exit) |
Writes a new version of the partition table and exits the fdisk menu. |
Cancel (exit without updating disk configuration) |
Exits the fdisk menu without modifying the partition table. |
