Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ] #include <mlib.h> mlib_status mlib_ImageXProj(mlib_d64 *xproj, const mlib_image *img);
The mlib_ImageXProj() function computes the sum of the pixels in each column of the source image.
The image must be a single-channel image.
It uses the following equation:
h-1
xproj[x] = SUM img[x][y][0]
y=0
where x = 0, 1, ..., w - 1.
The function takes the following arguments:
Pointer to X-projection vector, where length is equal to the number of columns in the source image (in other words, the image width).
Pointer to an input image.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
