Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ] #include <mlib.h> mlib_status mlib_ImageYProj_Fp(mlib_d64 *yproj, const mlib_image *img);
The mlib_ImageYProj_Fp() function computes the sum of the pixels in each row of the floating-point source image.
The image must be a single-channel image.
It uses the following equation:
           w-1
yproj[y] = SUM img[x][y][0]
           x=0
where y = 0, 1, ..., h - 1.
The function takes the following arguments:
Pointer to Y-projection vector, where length is equal to the number of rows in the source image (in other words, the image height).
Pointer to an input image.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
| ATTRIBUTE TYPE | ATTRIBUTE VALUE |
| Interface Stability | Committed |
| MT-Level | MT-Safe |
