Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ]
#include <mlib.h>
void mlib_VideoColorRGBint_to_ABGRint(mlib_u32 *ABGR,
const mlib_u8 *RGB, const mlib_u8 *A_array,
mlib_u8 A_const, mlib_s32 w,
mlib_s32 h, mlib_s32 dlb,
mlib_s32 slb, mlib_s32 alb);
The interleaved RGB stream, and the A values are combined into an A, B, G, R interleaved byte stream. Within each 24-bit input pixel, the component ordering is R (bits 23-16), G (bits 15-8), and B (bits 7-0). Within each 32-bit output word, the component ordering is A (bits 31-24), B (bits 23-16), G (bits 15-8), and R (bits 7-0).
The alpha values for this function work in the following fashion:
If A_array pointer is not NULL, the values are taken from there. It has to have the same dimensions as the R, G, and B buffers.
If A_array pointer is NULL, the alpha values for every pixel are set to A_const.
The function takes the following arguments:
Pointer to output buffer.
Pointer to input buffer.
Array of alpha values.
Constant alpha value.
Image width in pixels.
Image height in lines.
Linebytes for output buffer.
Linebytes for input buffer.
Linebytes for alpha buffer.
None.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
mlib_VideoColorRGBseq_to_ABGRint(3MLIB), mlib_VideoColorBGRint_to_ABGRint(3MLIB), mlib_VideoColorRGBXint_to_ABGRint(3MLIB), mlib_VideoColorRGBXint_to_ARGBint(3MLIB), mlib_VideoColorXRGBint_to_ABGRint(3MLIB), mlib_VideoColorXRGBint_to_ARGBint(3MLIB), attributes(5)
