Name | Synopsis | Description | Parameters | Return Values | Attributes | See Also
cc [ flag... ] file... -lmlib [ library... ]
#include <mlib.h>
void mlib_VideoColorXRGBint_to_ABGRint(mlib_u32 *ABGR,
const mlib_u32 *XRGB, const mlib_u8 *A_array,
mlib_u8 A_const, mlib_s32 w, mlib_s32 h,
mlib_s32 dlb, mlib_s32 slb, mlib_s32 alb);
Similar to mlib_VideoColorRGBXint_to_ABGRint except that the input component ordering is: R (bits 23-16), G (bits 15-8), and B (bits 7-0).
The function takes the following arguments:
Pointer to output buffer (word-aligned).
Pointer to input buffer (word-aligned).
Pointer to array of alpha values (byte-aligned).
Constant alpha value (range = 0..255).
Image width in pixels.
Image height in lines.
Linebytes for output buffer.
Linebytes for input buffer.
Linebytes for alphabuffer.
None.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Safe |
mlib_VideoColorRGBseq_to_ABGRint(3MLIB), mlib_VideoColorRGBint_to_ABGRint(3MLIB), mlib_VideoColorBGRint_to_ABGRint(3MLIB), mlib_VideoColorRGBXint_to_ABGRint(3MLIB), mlib_VideoColorRGBXint_to_ARGBint(3MLIB), mlib_VideoColorXRGBint_to_ARGBint(3MLIB), attributes(5)
