Solaris Trusted Extensions Installation and Configuration for Solaris 10 11/06 and Solaris 10 8/07 Releases
Configuring an LDAP Proxy Server on a Trusted Extensions Host (Task Map)
Use this task map if you have an existing Sun Java System Directory Server that is running on a Solaris system.
Task
Description
For Instructions
Add Trusted Extensions databases to the server.
The Trusted Extensions network databases, tnrhdb and tnrhtp, need to be added to the LDAP server.
Populate the Sun Java System Directory Server
Set up an LDAP proxy server.
Make one Trusted Extensions system the proxy server for the other Trusted Extensions systems. The other Trusted Extensions systems use this proxy server to reach the LDAP server.
Create an LDAP Proxy Server
Configure the proxy server to have a multilevel port for LDAP.
Enable the Trusted Extensions proxy server to communicate with the LDAP server at specific labels.
Configure a Multilevel Port for the Sun Java System Directory Server
Configure the Solaris Management Console to work with the LDAP proxy server.
You manually set up an LDAP toolbox for the Solaris Management Console. The toolbox can be used to modify Trusted Extensions attributes on network objects.
Configuring the Solaris Management Console for LDAP (Task Map)
Configure all other Trusted Extensions systems as clients of the LDAP proxy server.
When you configure another system with Trusted Extensions, make the system a client of the LDAP proxy server.
Make the Global Zone an LDAP Client in Trusted Extensions
