Oracle Solaris Trusted Extensions User's Guide
Window Label Indicator
The Window Label indicator displays the label of the active window. In a multilevel session, the indicator can help identify windows with different labels in the same workspace. The indicator can also show that you are interacting with the TCB. For example, when you change your password, the Trusted Path indicator displays in the trusted stripe.
Figure 4–5 Trusted Path Indicator in the Trusted Stripe
Screen shows the trusted stripe without the trusted symbol
and with a label of Trusted Path.
