Whenever you access any portion of the TCB, the trusted symbol appears at the left of the trusted stripe area. If your configuration suppresses labels, then the trusted symbol appears with the trusted stripe. In Trusted CDE, the symbol appears to the left of the Front Panel. In Trusted JDS, the symbol appears at the left of the trusted stripe.
The trusted symbol is not displayed when the pointer is focused in a window or area of the screen that does not affect security. The trusted symbol cannot be forged. If you see the symbol, you can be sure that you are safely interacting with the TCB.
If the trusted stripe is missing from your workspace, contact the security administrator. The problem with your system could be serious.
The trusted stripe should not appear during login, or when you lock your screen. If the trusted stripe shows, contact the administrator immediately.
