Trusted Extensions software manages all attempted security-related transactions. The software compares the subject's label with the object's label, then allows or disallows the transaction depending on which label is dominant. An entity's label is said to dominate another entity's label if the following two conditions are met:
The classification component of the first entity's label is equal to the object's classification or is higher than the object's classification.
All compartments in the second entity's labels are included in the first entity's label.
Two labels are said to be equal if the labels have the same classification and the same set of compartments. If the labels are equal, the labels dominate each other. Therefore, access is permitted.
If one of the following conditions is met, then the first label is said to strictly dominate the second label.
The first label has a higher classification than a second label
The first label's classification is equal to a second label's classification, the first label includes the second label's compartments, and the first label has additional compartments
A label that strictly dominates a second label is permitted access to the second label.
Two labels are said to be disjoint if neither label dominates the other label. Access is not permitted between disjoint labels.
For example, consider the following figure.
Four labels can be created from these components:
TOP SECRET
TOP SECRET A
TOP SECRET B
TOP SECRET AB
TOP SECRET AB dominates itself and strictly dominates the other labels. TOP SECRET A dominates itself and strictly dominates TOP SECRET. TOP SECRET B dominates itself and strictly dominates TOP SECRET. TOP SECRET A and TOP SECRET B are disjoint.
In a read transaction, the subject's label must dominate the object's label. This rule ensures that the subject's level of trust meets the requirements for access to the object. That is, the subject's label includes all compartments that are allowed access to the object. TOP SECRET A can read TOP SECRET A and TOP SECRET data. Similarly, TOP SECRET B can read TOP SECRET B and TOP SECRET data. TOP SECRET A cannot read TOP SECRET B data. Nor can TOP SECRET B read TOP SECRET A data. TOP SECRET AB can read the data at all labels.
In a write transaction, that is, when a subject creates or modifies an object, the resulting object's labeled zone must equal the subject's labeled zone. Write transactions are not allowed from one zone to a different zone.
In practice, subjects and objects in read and write transactions usually have the same label and strict dominance does not have to be considered. For example, a TOP SECRET A subject can create or modify a TOP SECRET A object. In Trusted Extensions, the TOP SECRET A object is in a zone that is labeled TOP SECRET A.
The following table illustrates dominance relationships among U.S. Government labels and among a set of industry labels.
Table 1–1 Examples of Label Relationships in Trusted Extensions|
Label 1 |
Relationship |
Label 2 |
U.S. Government Labels |
TOP SECRET AB |
(strictly) dominates |
SECRET A |
TOP SECRET AB |
SECRET A B |
TOP SECRET AB |
TOP SECRET A |
TOP SECRET AB |
dominates (equals) |
TOP SECRET AB |
TOP SECRET AB |
is disjoint with |
TOP SECRET C |
TOP SECRET AB |
is disjoint with |
SECRET C |
TOP SECRET AB |
is disjoint with |
SECRET A B C |
Industry Labels |
Confidential: Restricted |
dominates |
Confidential: Need to Know |
dominates |
Confidential: Internal Use Only |
dominates |
Public |
dominates |
dominates |
Public |
Confidential: Internal |
dominates |
Public |
Sandbox |
is disjoint with |
All other labels |
When you transfer information between files with different labels, Trusted Extensions displays a confirmation dialog box if you are authorized to change the label of the file. If you are not authorized to do so, Trusted Extensions disallows the transaction. The security administrator can authorize you to upgrade or downgrade information. For more information, see Performing Trusted Actions.
