The following security-related tasks require the trusted path.
If the trusted symbol is missing when you are attempting a security-related action, contact your security administrator at once. The problem on your system could be serious.
Unlike the Solaris OS, Trusted Extensions provides a GUI for changing your password. The GUI grabs the pointer until the password operation is completed. To stop a process that has grabbed the pointer, see How to Regain Control of the Desktop’s Current Focus in Oracle Solaris Trusted Extensions Administrator’s Procedures.
Choose Change Password from the Trusted Path menu.
Type your current password.
This action confirms that you are the legitimate user for this user name. For security reasons, the password is not displayed as you type.
When you type your password, make sure that the cursor is over the Change Password dialog box and that the trusted symbol is displayed. If the cursor is not over the dialog box, you might inadvertently type your password into a different window where the password could be seen by another user. If the trusted symbol is not displayed, then someone might be attempting to steal your password. Contact your security administrator at once.
Type the new password.
Confirm the password by retyping it.
The label of the first workspace that appears in subsequent login sessions after the first login can be set to any label within your label range.
Users can configure the startup session characteristics for every label at which they log in..
You must be logged in to a multilevel session.
Create workspaces at every label.
For details, see How to Add a Workspace at a Particular Label.
Configure each workspace as you want the workspace to appear.
Go to the workspace that you want to see when you log in.
Save this current workspace.
For details, see How to Perform Some Common Desktop Tasks in Trusted Extensions.
The Allocate Device menu item enables you to mount and allocate a device for your exclusive use. If you try to use a device without allocating it, you get the error message “Permission Denied”.
You must be authorized to allocate a device.
Choose Allocate Device from the Trusted Path menu
Or, in Trusted CDE, open the Device Allocation Manager from the Tools subpanel in the Front Panel.
The Device Allocation Manager is displayed. In Solaris Trusted Extensions (JDS), this GUI is called the Device Manager.
Double-click the device that you want to use.
The devices that you are permitted to allocate at your current label appear under Available Devices:.
audion – Indicates a microphone and speaker
cdromn – Indicates a CD-ROM drive
floppyn – Indicates a diskette drive
mag_tapen – Indicates a tape drive (streaming)
rmdiskn – Indicates a removable disk, such as a JAZ or ZIP drive, or USB hot-pluggable media
Select the device.
Move the device from the Available Devices list to the Allocated Devices list.
Double-click the device name in the Available Devices list.
Or, select the device and click the Allocate button that points to the right.
This step starts the clean script. The clean script ensures that no data from other transactions remains on the media.
Note that the label of the current workspace is applied to the device. Any data transferred to or from the device's media must be dominated by this label.
Follow the instructions.
The instructions ensure that the media has the correct label. For example, the following instructions appear for microphone use.
Then, the device is mounted. The device name now appears in the Allocated Devices list. This device is now allocated for your exclusive use.
In this example, a user wants to load information onto her system from a CD-ROM that is labeled SECRET. She is authorized to allocate the CD-ROM.
First, she creates a workspace at the label SECRET. In this workspace, she opens the Device Allocation Manager, and allocates the CD-ROM drive. Then, she inserts the CD and responds yes to the mount query.
The software mounts the CD and the File Manager appears. The current directory is set to the mount point.
In this example, a user allocates the audio device on her system. When she moves the audio device to the Allocated Device list, the following message appears:
The device is allocated at the label Confidential : Internal Use Only. She views the label when she selects the device in the Allocated Device list.
When the user is finished with the audio device, she deallocates it. The system reminds her to turn off the microphone.
If the device that you want to use does not appear in the list, check with your administrator. The device could be in an error state or in use by someone else. Or, you might not be authorized to use the device.
If you switch to a different role workspace or to a workspace at a different label, the allocated device cannot work at that label. To use the device at the new label, you need to deallocate the device at the initial label, and then allocate the device at the new label. In Trusted CDE, when you use the Occupy Workspace command from the window menu to move the Device Allocation Manager to the new workspace, the Available and Allocated Devices lists change to reflect the correct context. The Device Manager in Trusted JDS works similarly when you move the GUI to a workspace at a different label.
If a File Manager or File Browser window does not appear, open the window manually, then navigate to the root directory, /. In this directory, navigate to the allocated device to view its contents.
Deallocate the device.
Remove the media.
Click OK in the Deallocation dialog box.
The device is now available for use by another authorized user.
Unlike the Solaris OS, Trusted Extensions provides a GUI for assuming a role.
In Solaris Trusted Extensions (CDE), click the center of the Front Panel.
If you have been assigned a role by the security administrator, the Trusted Path menu includes the Assume rolename Role menu item.
Choose Assume rolename Role.
In Solaris Trusted Extensions (JDS), click your user name at the right of the trusted symbol.
Choose the role name from the menu.
Type the role password and press Return.
This action confirms that you can legitimately assume this role. For security reasons, the password is not displayed as you type.
After the role password is accepted, the software places you in a role workspace. In Trusted JDS, the current workspace becomes the role workspace. In Trusted CDE, a new workspace is created for the role. You are in the global zone. You can perform the tasks that are permitted by the rights profiles in your role.
The ability to set workspace labels in Trusted Extensions provides a convenient means of working at different labels within the same session.
Use this procedure to work in the same workspace at a different label. To create a workspace at a different label, see How to Add a Workspace at a Particular Label.
Change the workspace label of your current workspace.
Choose a label from the label builder.
The workspace label is changed to the new label. Windows and applications that were invoked before the label change continue to run at the previous label. The trusted stripe indicates the new label. In a system where labels are color-coded, new windows are marked with the new color. In Trusted CDE, the workspace button is color-coded. In Trusted JDS, the panel is color-coded.
The ability to set workspace labels in Trusted Extensions provides a convenient means of working at different labels within the same session. On both desktops, you can add a workspace at your minimum label. In Trusted CDE, you can add a workspace at the label of an existing workspace.
In Trusted CDE, rename each workspace button to reflect the label of the workspace.
To change the label of the current workspace, see How to Change the Label of a Workspace.
In Trusted JDS, to create a workspace at your minimum label, do the following:
Click mouse button 3 over a workspace panel.
From the menu, choose Preferences.
Increase the number in the Number of Workspaces field.
The new workspaces are created at your minimum label. You can also use this dialog box to name the workspaces. The name appears in the tooltip.
In Trusted JDS, to add a workspace at a different label, you select a workspace panel and change its label. For details, see How to Change the Label of a Workspace.
In Trusted CDE, to create a workspace at your minimum label, do the following:
In Trusted CDE, to create a workspace at the label of an existing workspace, do the following:
If you are logged in to a single-level session, you must log out to work at a different label. Then, log in at the desired label. If you are permitted, you can also log in to a multilevel session.
Windows that are moved to a different workspace retain their original label. Any actions that are done in those windows are done at the label of the window, not at the label of the containing workspace. Moving a window is useful when you want to compare information. You might also want to use applications at different labels without moving between workspaces.
To move a window to a different workspace, perform one of the following:
In Trusted CDE, use the Occupy Workspace menu.
From the application's window menu, choose Occupy Workspace.
Choose a workspace at a different label, then click OK.
This action moves the application to a workspace that has a different label. Note that the Occupy Workspace dialog box has the label Trusted Path. This label indicates that occupying a workspace affects the trusted computing base.
The following figure shows two terminal windows at different labels in one workspace.
In Trusted JDS, in the panel display, drag the window from its original workspace panel to a different panel.
The dragged window now appears in the second workspace.
Usually, the label of a file is obvious. However, if you are allowed to view files at a lower label than your current workspace, the label of a file might not be obvious. In particular, the label of a file can be different from the label of the File Browser or File Manager.
In Trusted CDE, use the File Manager to determine the label of the file.
In Trusted JDS, use the File Browser.
You can also use the Query Label menu item from the Trusted Path menu.
As on a Solaris system, you can move data between windows in Trusted Extensions. However, the data must be at the same label. When you transfer information between windows with different labels, you are upgrading or downgrading the sensitivity of that information.
Your site's security policy must permit this type of transfer, the containing zone must permit relabeling, and you must be authorized to move data between labels.
Therefore, your administrator must have completed the following tasks:
Create workspaces at both labels.
Confirm the label of the source file.
For details, see How to Determine the Label of a File.
Move the window with the source information to a workspace at the target label.
For details, see How to Move a Window to a Different Workspace. The following figure shows two editors at different labels in the same workspace.
Highlight the information to be moved, and paste the selection in the target window.
The Selection Manager Confirmation dialog box is displayed.
Review the Selection Manager Confirmation dialog box.
This dialog box:
Describes why confirmation of the transaction is needed.
Identifies the label and the owner of the source file.
Identifies the label and the owner of the destination file.
Identifies the type of data that was selected for transfer, the type of the target file, and the size of the data in bytes. By default, the selected data is visible in text format.
Indicates the time that remains for you to complete the transaction. The amount of time and the use of the timer depends on your site's configuration.
(Optional) In the View As menu, choose how to view the source information.
Confirm that you want the label of the data to change.
As on a standard Solaris system, you can move files in Trusted Extensions. When you move a file to a different label, you are upgrading or downgrading the sensitivity of the information that is in the file.
Your site's security policy must permit this type of transfer, the containing zone must permit relabeling, and you must be authorized to move files between labels.
You must be logged in to a multilevel session in Trusted CDE. The file that you want to move must be closed. Verify that no one else is using this file.
Open File Managers at both labels.
For details, see How to View Your Files in a Labeled Workspace.
In the source File Manager, navigate to the file whose label is to change.
In the target File Manager, navigate to the file's new directory.
Move the File Managers into one workspace.
Drag and drop the file to the target directory.
The File Manager Confirmation dialog box is displayed, as shown in Figure 3–18.
This dialog box is similar to the Selection Manager Confirmation dialog box, but does not include a timer. This dialog box:
Confirm that you want the label of the file to change.
The linking of a file to another label is useful when you want to view a file with a lower label at a higher label. The file is writable only at the lower label.
To link a file, the user presses Shift-Control while dragging the file icon from the source File Manager to the target File Manager. Then, the user confirms the link, or cancels the operation.
If your system is not configured to permit the upgrading or downgrading of labels, a dialog box that states that the transfer is not authorized is displayed. Check with your administrator.
