Oracle Solaris Trusted Extensions Label Administration
ProcedureHow to Specify Default User Labels
Before You Begin
You must be in the Security Administrator role in the global zone.
  1. Edit the label_encodings file.
    Use the Edit Encodings action. For details, see How to Create a label_encodings File.
  2. Find the line in the LOCAL DEFINITIONS section that begins with Default User Sensitivity Label.
    Default User Sensitivity Label= u;
    Default User Clearance= c;
  3. Replace the sensitivity label with your desired minimum user label.
    The following example shows a new minimum label of c.
    Default User Sensitivity Label= c;
  4. Replace the clearance with your desired user clearance.
    The following example shows a new clearance of s.
    Default User Clearance= s;
