This chapter describes known issues with specific applications in the Java Desktop System Release 3.
Platform |
Problem |
Change Request Number: 6227803 If you unplug a camera device from your system while Video Conferencing is running, your system hangs and you must reboot. |
Solution |
Do not unplug a camera
device while |
Platform |
Problem |
Change Request Number: 6238083 When you perform an installation using DHCP, the DNS domain name is entered as the NIS domain. The installation process requires several minutes to set your system up as an NIS client. |
Solution |
Platform |
Problem |
Change Request Number: 6261477 The following error message is displayed when you login after you upgrade from Java Desktop System Release 2 to Java Desktop System Release 3: You have a keyboard remapping file (.Xmodmap) in your home directory whose contents will now be ignored. You can use the keyboard preferences to restore them |
Solution |
Platform |
Problem |
Change Request Number: 6192644 The keyboard shortcut Ctrl+Home does not work correctly when browsing www.yahoo.com and www.mozilla.org with When caret browsing is on, this keyboard shortcut moves the caret to the beginning of the web page. |
Solution |
Press F7 to turn off caret browsing. |
Platform |
Problem |
Change Request Number: 6262947
Solution |
See also 2.10.1 Problems Using RealPlayer Files. |
Platform |
Problem |
Change Request Number: 6260762
Solution |
Save the PDF file to
your local disk and open it with |
Platform |
Problem |
Change Request Number: 6238266 The audio output from
Solution |
Use When you run However, if you have already configured
See also 2.7.3 Mozilla . |
Platform |
Problem |
Change Request Number: 6268743
Solution |
Platform |
Problem |
Change Request Number: 6272313 The |
Solution |
When you return to
a |
Platform |
Problem |
Change Request Number: 6283252 Some typed characters might be dropped on single CPU W1100x workstations if you type too fast. |
Solution |
