Java Desktop System Release 3 User Guide
Window Shortcut Keys
Window shortcut keys enable you to use the keyboard to perform window tasks. The following table lists some window shortcut keys:
Default Shortcut Keys
Function
Alt + Tab
Switches between windows. When you use these shortcut keys, a list of windows that you can select is displayed. Release the keys to select a window.
Alt + Esc
Switches between windows in reverse order. Release the keys to select a window.
F10
Opens the first menu on the left side of the menubar.
Alt + spacebar
Opens the Window Menu.
Arrow keys
Moves the focus between items in a menu.
Return
Chooses a menu item.
Esc
Closes an open menu.
Ctrl + Alt + right arrow
Switches to the workspace to the right of the current workspace.
Ctrl + Alt + left arrow
Switches to the workspace to the left of the current workspace.
Ctrl + Alt + up arrow
Switches to the workspace above the current workspace.
Ctrl + Alt + down arrow
Switches to the workspace below the current workspace.
Ctrl + Alt + d
Minimizes all windows, and gives focus to the desktop background.
