Panel shortcut keys enable you to use the keyboard to perform panel tasks. The following table lists panel shortcut keys:
Default Shortcut Keys |
Function |
Ctrl + Alt + Tab |
Switches the focus between the panels and the desktop background. When you use these shortcut keys, a list of items that you can select is displayed. Release the keys to select an item. |
Ctrl + Alt + Esc |
Switches the focus between the panels and the desktop background. Release the keys to select an item. |
Ctrl + F10 |
Opens the popup menu for the selected panel. |
Tab |
Switches the focus between objects on a panel. |
Return |
Chooses the selected panel object or menu item. |
Shift + F10 |
Opens the popup menu for the selected panel object. |
Arrow keys |
Moves the focus between items in a menu. Moves the focus between interface items in an applet also. |
Esc |
Closes an open menu. |
F10 |
Opens the Applications menu from the |
